| | Re: HOW: Read dynamic control on postback Hello JP, Quote: > I think I finally got this thing figured out. Granted it takes a bit > of code. > > Basically I'm generating the dynamic controls in the > gridview.RowDataBound() Then in GridView.DataBound() if EVENTTARGET > that generates the GridView is what fired the AJAX post back, I'm > cycling though all the controls for each row in the given cell and > adding them to a Control[row#,control object] type array so I can > maintain all the properties that were set. I then store this array in > a session. > > Then on post back, I check the page EVENTTARGET to ensure that the > object that generated the full post back was the submit button > otherwise I don't want to waste time cycling through the array. > > I make sure the session value is not null and convert it back to the > Control[,] array. I cycling though the array OnPage_Load, I simply > cycle though GridViewRows and do Controls.Add to the cell using the > object stored in the array. > > So far seems to work. I have some other tweaks I need to make though > but I've gotten over a major hurdle. > > You have been a huge help. data is page specific. It was a pleasure helping .Jesse Quote: > > "Jesse Houwing" wrote: > Quote: >> Hello JP, >> Quote: >>> Ok, this might pose a problem then if the dynamic controls are in a >>> GridView. >>> >>> In the page life cycle Page_Init occurs before Page_Load with >>> viewsate becoming available just before Page_Load occurs. >>> >>> The way I understand it is that on postback ,the dynamic controls >>> have be added to the back to the collection in the Page_Init method. >>> Since this method occurs before the Page_Load method, there is no >>> GridView object to add the controls back to because the postback >>> data wont regenerate the gridview until it executes the Page_Load >>> Method. >>> >> EnsureChildControls(); is called on the page. After that it should be >> in the right state. You can override EnsureChildControls to add the >> controls where needed at the right time. The grid control will make >> sure it will have empty rows added, no data just yet. That's the time >> to ensure your textboxes get in there as well. >> >> JEsse >> Quote: >>> "Jesse Houwing" wrote: >>> >>>> Hello JP, >>>> >>>>> So what you are saying is that after the user clicks submit >>>>> (postback), I still have to add the control back to the >>>>> collection, before I can see what the user typed? If thats true, >>>>> how does the view state know that the properties belong to the >>>>> dynamic control? >>>>> >>>> The value has been added to the viewstate in the same tree >>>> structure as the controls were in. The control will get the right >>>> values from the viewstate as long as you add it as follows: >>>> >>>> TextBox tb = new TextBox(); >>>> tb.ID = "id"; >>>> row.Add(tb); >>>> e.g. It is important to set the ID before adding the control to the >>>> tree. >>>> Anything else, you need to set after adding the control to the >>>> control tree, that way anything which was written from ViewState >>>> will succesfully be read and applied, before any other changes are >>>> done to the control. >>>> >>>>> I assume this is where the protected override void >>>>> OnInit(EventArgs e) comes in to play? In this particular >>>>> situation, I do want to maintain the value for postback solely for >>>>> the purposes of storing it in the database, but I do not want to >>>>> re-render the page after the postback. >>>>> >>>> The Grid usually has a RowCreated event, which will be fired when >>>> the control tree is being recreated. That is the moment you can >>>> safely add the control and re-apply eventsubscriptions for teh >>>> specific control. This will also allow any event you subscribed to >>>> to be fired after Page_Load. >>>> >>>> Then later in a databinding event, or in or after the Page_Load, >>>> you can change any value in the control or remove it altogether. >>>> >>>> Jesse >>>> >>>>> "Jesse Houwing" wrote: >>>>> >>>>>> Hello JP, >>>>>> >>>>>> Did you re-add the control to the grid before reading it's value? >>>>>> A dynamically added crontrol will need to be added back to the >>>>>> control tree on every subsequent request, should you want to >>>>>> access its value... >>>>>> >>>>>> Jesse >>>>>> >>>>>>> You are absolutely correct. I mistakenly typed my example in >>>>>>> this message. This statement is inside a foreach loop that >>>>>>> should have read as follows: >>>>>>> >>>>>>> foreach (GridViewRow gvr in gridQuestions.Rows) >>>>>>> { >>>>>>> //txtTransID is the dynamically generated control but this >>>>>>> always >>>>>>> returns null or error >>>>>>> string a = ((TextBox)gvr.FindControl("txtTransID")).Text; >>>>>>> } >>>>>>> "Jesse Houwing" wrote: >>>>>>>> Hello JP, >>>>>>>> >>>>>>>>> I created a page that has dynamically created TextBox or >>>>>>>>> DropDownList controls. >>>>>>>>> >>>>>>>>> However once the text box is filled in and I submit the page, >>>>>>>>> I cannot find the dynamic control. I have been all over the >>>>>>>>> net looking for an answer. I read the article from >>>>>>>>> 4GuysFromRolla but it still does not answer my question. >>>>>>>>> >>>>>>>>> How to I retrieve the values from a dynamically created >>>>>>>>> control on postback? >>>>>>>>> >>>>>>>>> This was the name of the control I added to a GridView (AJAX >>>>>>>>> call) >>>>>>>>> >>>>>>>>> TextBox controlTextBox = new TextBox(); >>>>>>>>> controlTextBox.EnableViewState = true; >>>>>>>>> controlTextBox.ID = "txt" + >>>>>>>>> drControls["controlName"].ToString(); >>>>>>>>> controlTextBox.MaxLength = 6; >>>>>>>>> controlTextBox.Width = 150; >>>>>>>>> controlTextBox.Enabled = true; >>>>>>>>> controlTextBox.Visible = true; >>>>>>>>> controlTextBox.Attributes.Add("runat", "server"); //just for >>>>>>>>> the >>>>>>>>> heck of it >>>>>>>>> e.Row.Cells[2].Controls.Add(controlTextBox); >>>>>>>>> (All is well at this point and the control is visible on the >>>>>>>>> page) >>>>>>>>> if(IsPostBack) >>>>>>>>> { >>>>>>>>> //Control never found >>>>>>>>> string Answer= >>>>>>>>> ((TextBox)GridView.FindControl("txtTransID")).Text; >>>>>>>>> } >>>>>>>>> I understand that the control itself (GUI representation) >>>>>>>>> needs >>>>>>>>> to >>>>>>>>> be >>>>>>>>> recreated, but should not the control properties be in the >>>>>>>>> viewstate >>>>>>>>> to access them? >>>>>>>>> PLEASE HELP! Does anyone have a working example? I could care >>>>>>>>> less >>>>>>>>> that the controls get re-rendered on the postback as they get >>>>>>>>> redirected to a different screen after the data saves, but I >>>>>>>>> really >>>>>>>>> need to just access the value >>>>>>>> The control is added to a naming container (the grid), which >>>>>>>> makes sure the control name is unique per row (each row will >>>>>>>> contain the specified textbox). >>>>>>>> >>>>>>>> So you'll have to query the specific row of the grid control in >>>>>>>> order to use FindControl. >>>>>>>> >>>>>>>> eg >>>>>>>> >>>>>>>> foreach (GridRow r in Grid.Rows) >>>>>>>> { >>>>>>>> r.FindControl("txtTransID"); >>>>>>>> } >>>>>>>> should do the trick >>>>>>>> -- >>>>>>>> Jesse Houwing >>>>>>>> jesse.houwing at sogeti.nl >>>>>> -- >>>>>> Jesse Houwing >>>>>> jesse.houwing at sogeti.nl >>>> -- >>>> Jesse Houwing >>>> jesse.houwing at sogeti.nl >> Jesse Houwing >> jesse.houwing at sogeti.nl Jesse Houwing jesse.houwing at sogeti.nl |
| HOW: Read dynamic control on postback | .NET General | |||
| Can't read appSettings of IE hosted control when under SSL | .NET General | |||
| Read messages turn UN-read again | Live Mail | |||
| READ THIS IF YOU CANNOT GET DRIVE TO READ DISK TO FIX VISTA ERROR! | Vista hardware & devices | |||
| Folders/files read only/can't create new folder in read only folde | Vista account administration | |||
