| | using .bas in C# or VB.Net I have a couple of .bas files and i need to use them in C#. I read Riquel_Dong reply that I need to compile them to COM dll files and use them. How do I compile .bas to dll? I saw another place: fbc -dll myfile.bas but its using freebasic and i could'nt understand it. Any other way. Sorry didnt know in which group to post. |
| | Re: using .bas in C# or VB.Net In Visual Studio Net there is a converter for Bas to VB but not to C#/ Be aware that probably the converter gives you a lot remarks to do as a module written in the older VB dialects is often not very clean written or have a lot of escapes to Win32 to do things which where in those days not possible direct in VB code. Cor "amk_hawk" <amkhawk@xxxxxx> wrote in message news B7EA3CA-F0A5-4586-A5F9-A625A0CF764C@xxxxxxQuote: >I have a couple of .bas files and i need to use them in C#. I read > Riquel_Dong reply that I need to compile them to COM dll files and use > them. > How do I compile .bas to dll? > I saw another place: > fbc -dll myfile.bas > but its using freebasic and i could'nt understand it. Any other way. > > Sorry didnt know in which group to post. |
| | Re: using .bas in C# or VB.Net Unless the older .bas file has a lot of file IO or Windows API calls in it, I've had better luck simply making a copy of the .bas file and renaming that copy to .VB. I then add the .vb file to my project and add the lines "Option Strict On", "Option Explicit On", and "Option Compare Text". Then I deal with the errors. My experience doing this type of conversion is that far more of my code converts to VB2005/8 than the project converter and without all the garbage comments that the converter inserts. Mike. "Cor Ligthert[MVP]" <Notmyfirstname@xxxxxx> wrote in message news:%23yKzu6duJHA.4488@xxxxxx Quote: > In Visual Studio Net there is a converter for Bas to VB but not to C#/ > > Be aware that probably the converter gives you a lot remarks to do as a > module written in the older VB dialects is often not very clean written or > have a lot of escapes to Win32 to do things which where in those days not > possible direct in VB code. > > Cor > > "amk_hawk" <amkhawk@xxxxxx> wrote in message > news B7EA3CA-F0A5-4586-A5F9-A625A0CF764C@xxxxxxQuote: >>I have a couple of .bas files and i need to use them in C#. I read >> Riquel_Dong reply that I need to compile them to COM dll files and use >> them. >> How do I compile .bas to dll? >> I saw another place: >> fbc -dll myfile.bas >> but its using freebasic and i could'nt understand it. Any other way. >> >> Sorry didnt know in which group to post. > |
| | Re: using .bas in C# or VB.Net My experience with both VB and VB.NET and VS is that you can easily get your VB code to *work* in VB .NET, but that doesn't mean that the code is in any way efficient or taking advantage of .NET's true power. Simply turning on the extra compiler checks doesn't force you to abandon legacy VB functions in favor of .NET framework objeccts and methods. A perfect example is the VB C***() conversion functions, which are designed to take in any data type (make that object in .NET) and return back the desired data type (make that object in .NET). When trying to go from a value type to another value type (like integer to long integer), excessive boxing/unboxing occurs. This will *work*, but far more efficient is the .NET convert class, which has many overloaded To***() methods, each one written to accomodate a particular input type and avoid these unneccessary boxing/unboxing operations. In the end, if you really want an application to take advantage of all that ..NET has to offer, the brutal truth is that you shouldn't try to convert the application, you should rewrite it. Of course, that is not always practical and so, we wind up with a lot of poorly written VB.NET that started out its life as VB 6.0. I work with many companies that outsource the coversion of their VB 6.0 applications and when those applications come back (from India usually), they run slower and have more bugs than before they were converted. This leads many managers (who aren't programmers) to the incorrect conclusion that .NET isn't worth the hype, when in fact, they're just dealing with poorly written code, which you can write in any language for any platform! -Scott "Michael D. Ober" <obermd.@xxxxxx> wrote in message news:-PednfdLapuBO33UnZ2dnUVZ_jednZ2d@xxxxxx Quote: > Unless the older .bas file has a lot of file IO or Windows API calls in > it, I've had better luck simply making a copy of the .bas file and > renaming that copy to .VB. I then add the .vb file to my project and add > the lines "Option Strict On", "Option Explicit On", and "Option Compare > Text". Then I deal with the errors. My experience doing this type of > conversion is that far more of my code converts to VB2005/8 than the > project converter and without all the garbage comments that the converter > inserts. > > Mike. > > "Cor Ligthert[MVP]" <Notmyfirstname@xxxxxx> wrote in message > news:%23yKzu6duJHA.4488@xxxxxx Quote: >> In Visual Studio Net there is a converter for Bas to VB but not to C#/ >> >> Be aware that probably the converter gives you a lot remarks to do as a >> module written in the older VB dialects is often not very clean written >> or have a lot of escapes to Win32 to do things which where in those days >> not possible direct in VB code. >> >> Cor >> >> "amk_hawk" <amkhawk@xxxxxx> wrote in message >> news B7EA3CA-F0A5-4586-A5F9-A625A0CF764C@xxxxxxQuote: >>>I have a couple of .bas files and i need to use them in C#. I read >>> Riquel_Dong reply that I need to compile them to COM dll files and use >>> them. >>> How do I compile .bas to dll? >>> I saw another place: >>> fbc -dll myfile.bas >>> but its using freebasic and i could'nt understand it. Any other way. >>> >>> Sorry didnt know in which group to post. >> > > |
| | Re: using .bas in C# or VB.Net Scott, Well put. If I have the time, I rewrite as it tends to generate more efficient code. Mike Ober. "Scott M." <s-mar@xxxxxx> wrote in message news:%23smom2ruJHA.5392@xxxxxx Quote: > My experience with both VB and VB.NET and VS is that you can easily get > your VB code to *work* in VB .NET, but that doesn't mean that the code is > in any way efficient or taking advantage of .NET's true power. Simply > turning on the extra compiler checks doesn't force you to abandon legacy > VB functions in favor of .NET framework objeccts and methods. > > A perfect example is the VB C***() conversion functions, which are > designed to take in any data type (make that object in .NET) and return > back the desired data type (make that object in .NET). > > When trying to go from a value type to another value type (like integer to > long integer), excessive boxing/unboxing occurs. This will *work*, but > far more efficient is the .NET convert class, which has many overloaded > To***() methods, each one written to accomodate a particular input type > and avoid these unneccessary boxing/unboxing operations. > > In the end, if you really want an application to take advantage of all > that .NET has to offer, the brutal truth is that you shouldn't try to > convert the application, you should rewrite it. Of course, that is not > always practical and so, we wind up with a lot of poorly written VB.NET > that started out its life as VB 6.0. > > I work with many companies that outsource the coversion of their VB 6.0 > applications and when those applications come back (from India usually), > they run slower and have more bugs than before they were converted. This > leads many managers (who aren't programmers) to the incorrect conclusion > that .NET isn't worth the hype, when in fact, they're just dealing with > poorly written code, which you can write in any language for any platform! > > -Scott > > > "Michael D. Ober" <obermd.@xxxxxx> wrote in message > news:-PednfdLapuBO33UnZ2dnUVZ_jednZ2d@xxxxxx Quote: >> Unless the older .bas file has a lot of file IO or Windows API calls in >> it, I've had better luck simply making a copy of the .bas file and >> renaming that copy to .VB. I then add the .vb file to my project and add >> the lines "Option Strict On", "Option Explicit On", and "Option Compare >> Text". Then I deal with the errors. My experience doing this type of >> conversion is that far more of my code converts to VB2005/8 than the >> project converter and without all the garbage comments that the converter >> inserts. >> >> Mike. >> >> "Cor Ligthert[MVP]" <Notmyfirstname@xxxxxx> wrote in message >> news:%23yKzu6duJHA.4488@xxxxxx Quote: >>> In Visual Studio Net there is a converter for Bas to VB but not to C#/ >>> >>> Be aware that probably the converter gives you a lot remarks to do as a >>> module written in the older VB dialects is often not very clean written >>> or have a lot of escapes to Win32 to do things which where in those days >>> not possible direct in VB code. >>> >>> Cor >>> >>> "amk_hawk" <amkhawk@xxxxxx> wrote in message >>> news B7EA3CA-F0A5-4586-A5F9-A625A0CF764C@xxxxxx>>>>I have a couple of .bas files and i need to use them in C#. I read >>>> Riquel_Dong reply that I need to compile them to COM dll files and use >>>> them. >>>> How do I compile .bas to dll? >>>> I saw another place: >>>> fbc -dll myfile.bas >>>> but its using freebasic and i could'nt understand it. Any other way. >>>> >>>> Sorry didnt know in which group to post. >>> >>> |
| | #6 (permalink) |
| | Re: using .bas in C# or VB.Net Scott, What you call legacy Visual Basic code? You are talking about micro optimizing wich often don't make any sense. It looks like you optimize in the 80% part of your code that is used 20% by the program. Beside that you tell to deoptimize by removing Functions like CDate and ChrW, which are simply given optimized functions around the DateTime and String classes. By the way, boxing and unboxing is not that bad in .Net as it was in history. Try to avoid refresh the screen and those things, that optimizes a program. Not that micro optimizing that saves you a thousand of a pico second. If a VB6 program is poorly rewritten is not the fact of these functions. Simply putting Option Strict in top of your program and get by that rid of late binding makes the program much faster, as VB functions are used mostly even faster. On the other hand I see often people who want for whaterver reason use Reflection. That is moslty simply using late binding. I seldom see comments about using unnecessary Reflection then by a select part of the regulars in these dotNet newsgroups. Cor "Scott M." <s-mar@xxxxxx> wrote in message news:%23smom2ruJHA.5392@xxxxxx Quote: > My experience with both VB and VB.NET and VS is that you can easily get > your VB code to *work* in VB .NET, but that doesn't mean that the code is > in any way efficient or taking advantage of .NET's true power. Simply > turning on the extra compiler checks doesn't force you to abandon legacy > VB functions in favor of .NET framework objeccts and methods. > > A perfect example is the VB C***() conversion functions, which are > designed to take in any data type (make that object in .NET) and return > back the desired data type (make that object in .NET). > > When trying to go from a value type to another value type (like integer to > long integer), excessive boxing/unboxing occurs. This will *work*, but > far more efficient is the .NET convert class, which has many overloaded > To***() methods, each one written to accomodate a particular input type > and avoid these unneccessary boxing/unboxing operations. > > In the end, if you really want an application to take advantage of all > that .NET has to offer, the brutal truth is that you shouldn't try to > convert the application, you should rewrite it. Of course, that is not > always practical and so, we wind up with a lot of poorly written VB.NET > that started out its life as VB 6.0. > > I work with many companies that outsource the coversion of their VB 6.0 > applications and when those applications come back (from India usually), > they run slower and have more bugs than before they were converted. This > leads many managers (who aren't programmers) to the incorrect conclusion > that .NET isn't worth the hype, when in fact, they're just dealing with > poorly written code, which you can write in any language for any platform! > > -Scott > > > "Michael D. Ober" <obermd.@xxxxxx> wrote in message > news:-PednfdLapuBO33UnZ2dnUVZ_jednZ2d@xxxxxx Quote: >> Unless the older .bas file has a lot of file IO or Windows API calls in >> it, I've had better luck simply making a copy of the .bas file and >> renaming that copy to .VB. I then add the .vb file to my project and add >> the lines "Option Strict On", "Option Explicit On", and "Option Compare >> Text". Then I deal with the errors. My experience doing this type of >> conversion is that far more of my code converts to VB2005/8 than the >> project converter and without all the garbage comments that the converter >> inserts. >> >> Mike. >> >> "Cor Ligthert[MVP]" <Notmyfirstname@xxxxxx> wrote in message >> news:%23yKzu6duJHA.4488@xxxxxx Quote: >>> In Visual Studio Net there is a converter for Bas to VB but not to C#/ >>> >>> Be aware that probably the converter gives you a lot remarks to do as a >>> module written in the older VB dialects is often not very clean written >>> or have a lot of escapes to Win32 to do things which where in those days >>> not possible direct in VB code. >>> >>> Cor >>> >>> "amk_hawk" <amkhawk@xxxxxx> wrote in message >>> news B7EA3CA-F0A5-4586-A5F9-A625A0CF764C@xxxxxx>>>>I have a couple of .bas files and i need to use them in C#. I read >>>> Riquel_Dong reply that I need to compile them to COM dll files and use >>>> them. >>>> How do I compile .bas to dll? >>>> I saw another place: >>>> fbc -dll myfile.bas >>>> but its using freebasic and i could'nt understand it. Any other way. >>>> >>>> Sorry didnt know in which group to post. >>> >>> >> >> > |
| | #7 (permalink) |
| | Re: using .bas in C# or VB.Net I refer to any VB 6.0 function that still *works* in VB .NET, but does not correlate to a .NET BCL object directly, a "legacy" function. That includes just about all of the native VB 6.0 functions relating to data types. I'm using the Cxyz() functions as an example (and their use is discouraged in general for the reasons I've stated). I disagree with your 80/20 assumption and, in fact would say that these legacy functions are used far more than this. There really is no reason to choose these functions. They offer no improvement in performance and/or portability to other .NET languages (quite the contrary). Also, their use does not follow with the Object Oriented that VB .NET has. It's true that boxing/unboxing can't be avoided in many circumstances, but that's not a reason to allow it to happen when it can be avoided. The ability to avoid boxing/unboxing operations is one of the great benefits of the Generics collection types and is not a trivial. This topic has been debated since the inception of .NET and I've heard the argument that these functions are part of Microsoft.VisualBasic and therefore they are first-class .NET language elements, but again they are not needed - - not one of them. Each and every one of them have a .NET BCL counterpart/mechanism and those counterparts are used in an OO way. As an IT trainer, I know that in the Enterprise, there is no reason to learn these legacy functions because nothing is gained by their use. Lastly, there is no reason to think that Microsoft would support these mechanisms forever. For example, at some point, it's not inconcievable that MsgBox() would go away, in favor of MessageBox.Show(). -Scott "Cor Ligthert[MVP]" <Notmyfirstname@xxxxxx> wrote in message news:%23wrOLTwuJHA.5836@xxxxxx Quote: > Scott, > > What you call legacy Visual Basic code? > > You are talking about micro optimizing wich often don't make any sense. > > It looks like you optimize in the 80% part of your code that is used 20% > by the program. > > Beside that you tell to deoptimize by removing Functions like CDate and > ChrW, which are simply given optimized functions around the DateTime and > String classes. > > By the way, boxing and unboxing is not that bad in .Net as it was in > history. Try to avoid refresh the screen and those things, that optimizes > a program. Not that micro optimizing that saves you a thousand of a pico > second. > > If a VB6 program is poorly rewritten is not the fact of these functions. > Simply putting Option Strict in top of your program and get by that rid of > late binding makes the program much faster, as VB functions are used > mostly even faster. > > On the other hand I see often people who want for whaterver reason use > Reflection. That is moslty simply using late binding. I seldom see > comments about using unnecessary Reflection then by a select part of the > regulars in these dotNet newsgroups. > > Cor > > "Scott M." <s-mar@xxxxxx> wrote in message > news:%23smom2ruJHA.5392@xxxxxx Quote: >> My experience with both VB and VB.NET and VS is that you can easily get >> your VB code to *work* in VB .NET, but that doesn't mean that the code is >> in any way efficient or taking advantage of .NET's true power. Simply >> turning on the extra compiler checks doesn't force you to abandon legacy >> VB functions in favor of .NET framework objeccts and methods. >> >> A perfect example is the VB C***() conversion functions, which are >> designed to take in any data type (make that object in .NET) and return >> back the desired data type (make that object in .NET). >> >> When trying to go from a value type to another value type (like integer >> to long integer), excessive boxing/unboxing occurs. This will *work*, >> but far more efficient is the .NET convert class, which has many >> overloaded To***() methods, each one written to accomodate a particular >> input type and avoid these unneccessary boxing/unboxing operations. >> >> In the end, if you really want an application to take advantage of all >> that .NET has to offer, the brutal truth is that you shouldn't try to >> convert the application, you should rewrite it. Of course, that is not >> always practical and so, we wind up with a lot of poorly written VB.NET >> that started out its life as VB 6.0. >> >> I work with many companies that outsource the coversion of their VB 6.0 >> applications and when those applications come back (from India usually), >> they run slower and have more bugs than before they were converted. This >> leads many managers (who aren't programmers) to the incorrect conclusion >> that .NET isn't worth the hype, when in fact, they're just dealing with >> poorly written code, which you can write in any language for any >> platform! >> >> -Scott >> >> >> "Michael D. Ober" <obermd.@xxxxxx> wrote in message >> news:-PednfdLapuBO33UnZ2dnUVZ_jednZ2d@xxxxxx Quote: >>> Unless the older .bas file has a lot of file IO or Windows API calls in >>> it, I've had better luck simply making a copy of the .bas file and >>> renaming that copy to .VB. I then add the .vb file to my project and >>> add the lines "Option Strict On", "Option Explicit On", and "Option >>> Compare Text". Then I deal with the errors. My experience doing this >>> type of conversion is that far more of my code converts to VB2005/8 than >>> the project converter and without all the garbage comments that the >>> converter inserts. >>> >>> Mike. >>> >>> "Cor Ligthert[MVP]" <Notmyfirstname@xxxxxx> wrote in message >>> news:%23yKzu6duJHA.4488@xxxxxx >>>> In Visual Studio Net there is a converter for Bas to VB but not to C#/ >>>> >>>> Be aware that probably the converter gives you a lot remarks to do as a >>>> module written in the older VB dialects is often not very clean written >>>> or have a lot of escapes to Win32 to do things which where in those >>>> days not possible direct in VB code. >>>> >>>> Cor >>>> >>>> "amk_hawk" <amkhawk@xxxxxx> wrote in message >>>> news B7EA3CA-F0A5-4586-A5F9-A625A0CF764C@xxxxxx>>>>>I have a couple of .bas files and i need to use them in C#. I read >>>>> Riquel_Dong reply that I need to compile them to COM dll files and use >>>>> them. >>>>> How do I compile .bas to dll? >>>>> I saw another place: >>>>> fbc -dll myfile.bas >>>>> but its using freebasic and i could'nt understand it. Any other way. >>>>> >>>>> Sorry didnt know in which group to post. >>>> >>>> >>> >>> >>> >> |
| | #8 (permalink) |
| | Re: using .bas in C# or VB.Net Scott, Are you using in English as well only the Anglo Saxon set of words. English has a lot of synonyms because of the different tribes that have concoured England in history. So you eat flesh no meat because there is not any reason to call it flesh. Poor English and so is Visual Basic as you avoid using the words which makes it easier to describe things. By the way, why you are always writing about "vb6 functions", those keywords are and will be used in every version from vb even the scripting ones. vb6 has nothing to do with it. It is something different as you are talking about the Com objects like recordsets. Com can be used in every .Net language, however that is not advisable because it is mainly dedicated to Win32. jmo Cor "Scott M." <s-mar@xxxxxx> wrote in message news:ORRo$DxuJHA.5764@xxxxxx Quote: >I refer to any VB 6.0 function that still *works* in VB .NET, but does not >correlate to a .NET BCL object directly, a "legacy" function. That >includes just about all of the native VB 6.0 functions relating to data >types. > > I'm using the Cxyz() functions as an example (and their use is discouraged > in general for the reasons I've stated). I disagree with your 80/20 > assumption and, in fact would say that these legacy functions are used far > more than this. > > There really is no reason to choose these functions. They offer no > improvement in performance and/or portability to other .NET languages > (quite the contrary). Also, their use does not follow with the Object > Oriented that VB .NET has. > > It's true that boxing/unboxing can't be avoided in many circumstances, but > that's not a reason to allow it to happen when it can be avoided. The > ability to avoid boxing/unboxing operations is one of the great benefits > of the Generics collection types and is not a trivial. > > This topic has been debated since the inception of .NET and I've heard the > argument that these functions are part of Microsoft.VisualBasic and > therefore they are first-class .NET language elements, but again they are > not needed - - not one of them. Each and every one of them have a .NET > BCL counterpart/mechanism and those counterparts are used in an OO way. > > As an IT trainer, I know that in the Enterprise, there is no reason to > learn these legacy functions because nothing is gained by their use. > > Lastly, there is no reason to think that Microsoft would support these > mechanisms forever. For example, at some point, it's not inconcievable > that MsgBox() would go away, in favor of MessageBox.Show(). > > -Scott > > > "Cor Ligthert[MVP]" <Notmyfirstname@xxxxxx> wrote in message > news:%23wrOLTwuJHA.5836@xxxxxx Quote: >> Scott, >> >> What you call legacy Visual Basic code? >> >> You are talking about micro optimizing wich often don't make any sense. >> >> It looks like you optimize in the 80% part of your code that is used 20% >> by the program. >> >> Beside that you tell to deoptimize by removing Functions like CDate and >> ChrW, which are simply given optimized functions around the DateTime and >> String classes. >> >> By the way, boxing and unboxing is not that bad in .Net as it was in >> history. Try to avoid refresh the screen and those things, that optimizes >> a program. Not that micro optimizing that saves you a thousand of a pico >> second. >> >> If a VB6 program is poorly rewritten is not the fact of these functions. >> Simply putting Option Strict in top of your program and get by that rid >> of late binding makes the program much faster, as VB functions are used >> mostly even faster. >> >> On the other hand I see often people who want for whaterver reason use >> Reflection. That is moslty simply using late binding. I seldom see >> comments about using unnecessary Reflection then by a select part of the >> regulars in these dotNet newsgroups. >> >> Cor >> >> "Scott M." <s-mar@xxxxxx> wrote in message >> news:%23smom2ruJHA.5392@xxxxxx Quote: >>> My experience with both VB and VB.NET and VS is that you can easily get >>> your VB code to *work* in VB .NET, but that doesn't mean that the code >>> is in any way efficient or taking advantage of .NET's true power. >>> Simply turning on the extra compiler checks doesn't force you to abandon >>> legacy VB functions in favor of .NET framework objeccts and methods. >>> >>> A perfect example is the VB C***() conversion functions, which are >>> designed to take in any data type (make that object in .NET) and return >>> back the desired data type (make that object in .NET). >>> >>> When trying to go from a value type to another value type (like integer >>> to long integer), excessive boxing/unboxing occurs. This will *work*, >>> but far more efficient is the .NET convert class, which has many >>> overloaded To***() methods, each one written to accomodate a particular >>> input type and avoid these unneccessary boxing/unboxing operations. >>> >>> In the end, if you really want an application to take advantage of all >>> that .NET has to offer, the brutal truth is that you shouldn't try to >>> convert the application, you should rewrite it. Of course, that is not >>> always practical and so, we wind up with a lot of poorly written VB.NET >>> that started out its life as VB 6.0. >>> >>> I work with many companies that outsource the coversion of their VB 6.0 >>> applications and when those applications come back (from India usually), >>> they run slower and have more bugs than before they were converted. >>> This leads many managers (who aren't programmers) to the incorrect >>> conclusion that .NET isn't worth the hype, when in fact, they're just >>> dealing with poorly written code, which you can write in any language >>> for any platform! >>> >>> -Scott >>> >>> >>> "Michael D. Ober" <obermd.@xxxxxx> wrote in message >>> news:-PednfdLapuBO33UnZ2dnUVZ_jednZ2d@xxxxxx >>>> Unless the older .bas file has a lot of file IO or Windows API calls in >>>> it, I've had better luck simply making a copy of the .bas file and >>>> renaming that copy to .VB. I then add the .vb file to my project and >>>> add the lines "Option Strict On", "Option Explicit On", and "Option >>>> Compare Text". Then I deal with the errors. My experience doing this >>>> type of conversion is that far more of my code converts to VB2005/8 >>>> than the project converter and without all the garbage comments that >>>> the converter inserts. >>>> >>>> Mike. >>>> >>>> "Cor Ligthert[MVP]" <Notmyfirstname@xxxxxx> wrote in message >>>> news:%23yKzu6duJHA.4488@xxxxxx >>>>> In Visual Studio Net there is a converter for Bas to VB but not to C#/ >>>>> >>>>> Be aware that probably the converter gives you a lot remarks to do as >>>>> a module written in the older VB dialects is often not very clean >>>>> written or have a lot of escapes to Win32 to do things which where in >>>>> those days not possible direct in VB code. >>>>> >>>>> Cor >>>>> >>>>> "amk_hawk" <amkhawk@xxxxxx> wrote in message >>>>> news B7EA3CA-F0A5-4586-A5F9-A625A0CF764C@xxxxxx>>>>>>I have a couple of .bas files and i need to use them in C#. I read >>>>>> Riquel_Dong reply that I need to compile them to COM dll files and >>>>>> use them. >>>>>> How do I compile .bas to dll? >>>>>> I saw another place: >>>>>> fbc -dll myfile.bas >>>>>> but its using freebasic and i could'nt understand it. Any other way. >>>>>> >>>>>> Sorry didnt know in which group to post. >>>>> >>>>> >>>> >>>> >>>> >>> >>> > |
| | #9 (permalink) |
| | Re: using .bas in C# or VB.Net Correct me if I'm wrong, but I think the point you're trying to make is that these functions are part of the language, so why not use them if they help describe what is trying to be said. Correct? Well, I've already answered that question. Because there are *better* ways to describe the intent of your code than these outdated functions. Even though, as you point out, these functions were created much earlier than VB 6, I refer to them that way as a simple way of drawing a line between classic VB and VB .NET - don't read anything else into it than that. COM objects have nothing to do with this topic, in my opinion, because you may *have* to use a COM object in a .NET application, but you *never* have to use any of these legacy VB functions. As I said in my last post, these functions: - all have .NET counterparts - don't follow OO syntax/programming style - may not have continued supporte in the future - can degrade application performance These points can all be overcome by simply using the .NET framework. Given that, saying that "they are part of the language" just isn't good argument for their continued use. Let me cite just one (of many) references about this: From: Professional Visual Basic 2008 by Bill Evgen et al (page 45) "The following set of conversion methods is based on the conversions supported by Visual Basic. They coincide with the primitive data types described earlier; however, continued use of these methods is not considered a best practice. That bears repeating: Whil you may find the following methods in existing code, you should strive to avoid and replace these calls:" Following that paragraph is a complete list of the Visual Basic Cxyz() functions. To sum up, just because you can do something, doesn't mean that you should. There really isn't any complling reason to use these outdated and inefficient function calls. -Scott "Cor Ligthert[MVP]" <Notmyfirstname@xxxxxx> wrote in message news:uq54Q0xuJHA.4324@xxxxxx Quote: > Scott, > > Are you using in English as well only the Anglo Saxon set of words. > English has a lot of synonyms because of the different tribes that have > concoured England in history. > > So you eat flesh no meat because there is not any reason to call it flesh. > > Poor English and so is Visual Basic as you avoid using the words which > makes it easier to describe things. > > By the way, why you are always writing about "vb6 functions", those > keywords are and will be used in every version from vb even the scripting > ones. vb6 has nothing to do with it. > > It is something different as you are talking about the Com objects like > recordsets. Com can be used in every .Net language, however that is not > advisable because it is mainly dedicated to Win32. > > jmo > > Cor > > "Scott M." <s-mar@xxxxxx> wrote in message > news:ORRo$DxuJHA.5764@xxxxxx Quote: >>I refer to any VB 6.0 function that still *works* in VB .NET, but does not >>correlate to a .NET BCL object directly, a "legacy" function. That >>includes just about all of the native VB 6.0 functions relating to data >>types. >> >> I'm using the Cxyz() functions as an example (and their use is >> discouraged in general for the reasons I've stated). I disagree with your >> 80/20 assumption and, in fact would say that these legacy functions are >> used far more than this. >> >> There really is no reason to choose these functions. They offer no >> improvement in performance and/or portability to other .NET languages >> (quite the contrary). Also, their use does not follow with the Object >> Oriented that VB .NET has. >> >> It's true that boxing/unboxing can't be avoided in many circumstances, >> but that's not a reason to allow it to happen when it can be avoided. >> The ability to avoid boxing/unboxing operations is one of the great >> benefits of the Generics collection types and is not a trivial. >> >> This topic has been debated since the inception of .NET and I've heard >> the argument that these functions are part of Microsoft.VisualBasic and >> therefore they are first-class .NET language elements, but again they are >> not needed - - not one of them. Each and every one of them have a .NET >> BCL counterpart/mechanism and those counterparts are used in an OO way. >> >> As an IT trainer, I know that in the Enterprise, there is no reason to >> learn these legacy functions because nothing is gained by their use. >> >> Lastly, there is no reason to think that Microsoft would support these >> mechanisms forever. For example, at some point, it's not inconcievable >> that MsgBox() would go away, in favor of MessageBox.Show(). >> >> -Scott >> >> >> "Cor Ligthert[MVP]" <Notmyfirstname@xxxxxx> wrote in message >> news:%23wrOLTwuJHA.5836@xxxxxx Quote: >>> Scott, >>> >>> What you call legacy Visual Basic code? >>> >>> You are talking about micro optimizing wich often don't make any sense. >>> >>> It looks like you optimize in the 80% part of your code that is used 20% >>> by the program. >>> >>> Beside that you tell to deoptimize by removing Functions like CDate and >>> ChrW, which are simply given optimized functions around the DateTime and >>> String classes. >>> >>> By the way, boxing and unboxing is not that bad in .Net as it was in >>> history. Try to avoid refresh the screen and those things, that >>> optimizes a program. Not that micro optimizing that saves you a thousand >>> of a pico second. >>> >>> If a VB6 program is poorly rewritten is not the fact of these functions. >>> Simply putting Option Strict in top of your program and get by that rid >>> of late binding makes the program much faster, as VB functions are used >>> mostly even faster. >>> >>> On the other hand I see often people who want for whaterver reason use >>> Reflection. That is moslty simply using late binding. I seldom see >>> comments about using unnecessary Reflection then by a select part of the >>> regulars in these dotNet newsgroups. >>> >>> Cor >>> >>> "Scott M." <s-mar@xxxxxx> wrote in message >>> news:%23smom2ruJHA.5392@xxxxxx >>>> My experience with both VB and VB.NET and VS is that you can easily get >>>> your VB code to *work* in VB .NET, but that doesn't mean that the code >>>> is in any way efficient or taking advantage of .NET's true power. >>>> Simply turning on the extra compiler checks doesn't force you to >>>> abandon legacy VB functions in favor of .NET framework objeccts and >>>> methods. >>>> >>>> A perfect example is the VB C***() conversion functions, which are >>>> designed to take in any data type (make that object in .NET) and return >>>> back the desired data type (make that object in .NET). >>>> >>>> When trying to go from a value type to another value type (like integer >>>> to long integer), excessive boxing/unboxing occurs. This will *work*, >>>> but far more efficient is the .NET convert class, which has many >>>> overloaded To***() methods, each one written to accomodate a particular >>>> input type and avoid these unneccessary boxing/unboxing operations. >>>> >>>> In the end, if you really want an application to take advantage of all >>>> that .NET has to offer, the brutal truth is that you shouldn't try to >>>> convert the application, you should rewrite it. Of course, that is not >>>> always practical and so, we wind up with a lot of poorly written VB.NET >>>> that started out its life as VB 6.0. >>>> >>>> I work with many companies that outsource the coversion of their VB 6.0 >>>> applications and when those applications come back (from India >>>> usually), they run slower and have more bugs than before they were >>>> converted. This leads many managers (who aren't programmers) to the >>>> incorrect conclusion that .NET isn't worth the hype, when in fact, >>>> they're just dealing with poorly written code, which you can write in >>>> any language for any platform! >>>> >>>> -Scott >>>> >>>> >>>> "Michael D. Ober" <obermd.@xxxxxx> wrote in message >>>> news:-PednfdLapuBO33UnZ2dnUVZ_jednZ2d@xxxxxx >>>>> Unless the older .bas file has a lot of file IO or Windows API calls >>>>> in it, I've had better luck simply making a copy of the .bas file and >>>>> renaming that copy to .VB. I then add the .vb file to my project and >>>>> add the lines "Option Strict On", "Option Explicit On", and "Option >>>>> Compare Text". Then I deal with the errors. My experience doing this >>>>> type of conversion is that far more of my code converts to VB2005/8 >>>>> than the project converter and without all the garbage comments that >>>>> the converter inserts. >>>>> >>>>> Mike. >>>>> >>>>> "Cor Ligthert[MVP]" <Notmyfirstname@xxxxxx> wrote in message >>>>> news:%23yKzu6duJHA.4488@xxxxxx >>>>>> In Visual Studio Net there is a converter for Bas to VB but not to >>>>>> C#/ >>>>>> >>>>>> Be aware that probably the converter gives you a lot remarks to do as >>>>>> a module written in the older VB dialects is often not very clean >>>>>> written or have a lot of escapes to Win32 to do things which where in >>>>>> those days not possible direct in VB code. >>>>>> >>>>>> Cor >>>>>> >>>>>> "amk_hawk" <amkhawk@xxxxxx> wrote in message >>>>>> news B7EA3CA-F0A5-4586-A5F9-A625A0CF764C@xxxxxx>>>>>>>I have a couple of .bas files and i need to use them in C#. I read >>>>>>> Riquel_Dong reply that I need to compile them to COM dll files and >>>>>>> use them. >>>>>>> How do I compile .bas to dll? >>>>>>> I saw another place: >>>>>>> fbc -dll myfile.bas >>>>>>> but its using freebasic and i could'nt understand it. Any other way. >>>>>>> >>>>>>> Sorry didnt know in which group to post. >>>>>> >>>>>> >>>>> >>>>> >>>>> >>>> >>>> >>> >> |
| | #10 (permalink) |
| | Re: using .bas in C# or VB.Net Scott, You should have seen that as somebody uses the term "best practise", I always write that he tells most probably something he has heard, what fits nice in what he thinks, but is not something he knows. The term "considered best practise" should always be followed by: because ........................................ Now it is stated as if the writter has talked about this with some friends in a bar and they decided that it was best practise. It is however something which is often told by people who know C# and think that they then can write a book about Visual Basic because the System namespace is used in both. Cor "Scott M." <s-mar@xxxxxx> wrote in message news:e5Ro2a3uJHA.4592@xxxxxx Quote: > Correct me if I'm wrong, but I think the point you're trying to make is > that these functions are part of the language, so why not use them if they > help describe what is trying to be said. Correct? > > Well, I've already answered that question. Because there are *better* > ways to describe the intent of your code than these outdated functions. > > Even though, as you point out, these functions were created much earlier > than VB 6, I refer to them that way as a simple way of drawing a line > between classic VB and VB .NET - don't read anything else into it than > that. > > COM objects have nothing to do with this topic, in my opinion, because you > may *have* to use a COM object in a .NET application, but you *never* have > to use any of these legacy VB functions. > > As I said in my last post, these functions: > > - all have .NET counterparts > - don't follow OO syntax/programming style > - may not have continued supporte in the future > - can degrade application performance > > These points can all be overcome by simply using the .NET framework. > Given that, saying that "they are part of the language" just isn't good > argument for their continued use. > > Let me cite just one (of many) references about this: > > From: Professional Visual Basic 2008 by Bill Evgen et al (page 45) > > "The following set of conversion methods is based on the conversions > supported by Visual Basic. They coincide with the primitive data types > described earlier; however, continued use of these methods is not > considered a best practice. That bears repeating: Whil you may find the > following methods in existing code, you should strive to avoid and replace > these calls:" > > Following that paragraph is a complete list of the Visual Basic Cxyz() > functions. > > To sum up, just because you can do something, doesn't mean that you > should. There really isn't any complling reason to use these outdated and > inefficient function calls. > > -Scott > > > "Cor Ligthert[MVP]" <Notmyfirstname@xxxxxx> wrote in message > news:uq54Q0xuJHA.4324@xxxxxx Quote: >> Scott, >> >> Are you using in English as well only the Anglo Saxon set of words. >> English has a lot of synonyms because of the different tribes that have >> concoured England in history. >> >> So you eat flesh no meat because there is not any reason to call it >> flesh. >> >> Poor English and so is Visual Basic as you avoid using the words which >> makes it easier to describe things. >> >> By the way, why you are always writing about "vb6 functions", those >> keywords are and will be used in every version from vb even the scripting >> ones. vb6 has nothing to do with it. >> >> It is something different as you are talking about the Com objects like >> recordsets. Com can be used in every .Net language, however that is not >> advisable because it is mainly dedicated to Win32. >> >> jmo >> >> Cor >> >> "Scott M." <s-mar@xxxxxx> wrote in message >> news:ORRo$DxuJHA.5764@xxxxxx Quote: >>>I refer to any VB 6.0 function that still *works* in VB .NET, but does >>>not correlate to a .NET BCL object directly, a "legacy" function. That >>>includes just about all of the native VB 6.0 functions relating to data >>>types. >>> >>> I'm using the Cxyz() functions as an example (and their use is >>> discouraged in general for the reasons I've stated). I disagree with >>> your 80/20 assumption and, in fact would say that these legacy functions >>> are used far more than this. >>> >>> There really is no reason to choose these functions. They offer no >>> improvement in performance and/or portability to other .NET languages >>> (quite the contrary). Also, their use does not follow with the Object >>> Oriented that VB .NET has. >>> >>> It's true that boxing/unboxing can't be avoided in many circumstances, >>> but that's not a reason to allow it to happen when it can be avoided. >>> The ability to avoid boxing/unboxing operations is one of the great >>> benefits of the Generics collection types and is not a trivial. >>> >>> This topic has been debated since the inception of .NET and I've heard >>> the argument that these functions are part of Microsoft.VisualBasic and >>> therefore they are first-class .NET language elements, but again they >>> are not needed - - not one of them. Each and every one of them have a >>> .NET BCL counterpart/mechanism and those counterparts are used in an OO >>> way. >>> >>> As an IT trainer, I know that in the Enterprise, there is no reason to >>> learn these legacy functions because nothing is gained by their use. >>> >>> Lastly, there is no reason to think that Microsoft would support these >>> mechanisms forever. For example, at some point, it's not inconcievable >>> that MsgBox() would go away, in favor of MessageBox.Show(). >>> >>> -Scott >>> >>> >>> "Cor Ligthert[MVP]" <Notmyfirstname@xxxxxx> wrote in message >>> news:%23wrOLTwuJHA.5836@xxxxxx >>>> Scott, >>>> >>>> What you call legacy Visual Basic code? >>>> >>>> You are talking about micro optimizing wich often don't make any sense. >>>> >>>> It looks like you optimize in the 80% part of your code that is used >>>> 20% by the program. >>>> >>>> Beside that you tell to deoptimize by removing Functions like CDate and >>>> ChrW, which are simply given optimized functions around the DateTime >>>> and String classes. >>>> >>>> By the way, boxing and unboxing is not that bad in .Net as it was in >>>> history. Try to avoid refresh the screen and those things, that >>>> optimizes a program. Not that micro optimizing that saves you a >>>> thousand of a pico second. >>>> >>>> If a VB6 program is poorly rewritten is not the fact of these >>>> functions. Simply putting Option Strict in top of your program and get >>>> by that rid of late binding makes the program much faster, as VB >>>> functions are used mostly even faster. >>>> >>>> On the other hand I see often people who want for whaterver reason use >>>> Reflection. That is moslty simply using late binding. I seldom see >>>> comments about using unnecessary Reflection then by a select part of >>>> the regulars in these dotNet newsgroups. >>>> >>>> Cor >>>> >>>> "Scott M." <s-mar@xxxxxx> wrote in message >>>> news:%23smom2ruJHA.5392@xxxxxx >>>>> My experience with both VB and VB.NET and VS is that you can easily >>>>> get your VB code to *work* in VB .NET, but that doesn't mean that the >>>>> code is in any way efficient or taking advantage of .NET's true power. >>>>> Simply turning on the extra compiler checks doesn't force you to >>>>> abandon legacy VB functions in favor of .NET framework objeccts and >>>>> methods. >>>>> >>>>> A perfect example is the VB C***() conversion functions, which are >>>>> designed to take in any data type (make that object in .NET) and >>>>> return back the desired data type (make that object in .NET). >>>>> >>>>> When trying to go from a value type to another value type (like >>>>> integer to long integer), excessive boxing/unboxing occurs. This will >>>>> *work*, but far more efficient is the .NET convert class, which has >>>>> many overloaded To***() methods, each one written to accomodate a >>>>> particular input type and avoid these unneccessary boxing/unboxing >>>>> operations. >>>>> >>>>> In the end, if you really want an application to take advantage of all >>>>> that .NET has to offer, the brutal truth is that you shouldn't try to >>>>> convert the application, you should rewrite it. Of course, that is >>>>> not always practical and so, we wind up with a lot of poorly written >>>>> VB.NET that started out its life as VB 6.0. >>>>> >>>>> I work with many companies that outsource the coversion of their VB >>>>> 6.0 applications and when those applications come back (from India >>>>> usually), they run slower and have more bugs than before they were >>>>> converted. This leads many managers (who aren't programmers) to the >>>>> incorrect conclusion that .NET isn't worth the hype, when in fact, >>>>> they're just dealing with poorly written code, which you can write in >>>>> any language for any platform! >>>>> >>>>> -Scott >>>>> >>>>> >>>>> "Michael D. Ober" <obermd.@xxxxxx> wrote in message >>>>> news:-PednfdLapuBO33UnZ2dnUVZ_jednZ2d@xxxxxx >>>>>> Unless the older .bas file has a lot of file IO or Windows API calls >>>>>> in it, I've had better luck simply making a copy of the .bas file and >>>>>> renaming that copy to .VB. I then add the .vb file to my project and >>>>>> add the lines "Option Strict On", "Option Explicit On", and "Option >>>>>> Compare Text". Then I deal with the errors. My experience doing >>>>>> this type of conversion is that far more of my code converts to >>>>>> VB2005/8 than the project converter and without all the garbage >>>>>> comments that the converter inserts. >>>>>> >>>>>> Mike. >>>>>> >>>>>> "Cor Ligthert[MVP]" <Notmyfirstname@xxxxxx> wrote in message >>>>>> news:%23yKzu6duJHA.4488@xxxxxx >>>>>>> In Visual Studio Net there is a converter for Bas to VB but not to >>>>>>> C#/ >>>>>>> >>>>>>> Be aware that probably the converter gives you a lot remarks to do >>>>>>> as a module written in the older VB dialects is often not very clean >>>>>>> written or have a lot of escapes to Win32 to do things which where >>>>>>> in those days not possible direct in VB code. >>>>>>> >>>>>>> Cor >>>>>>> >>>>>>> "amk_hawk" <amkhawk@xxxxxx> wrote in message >>>>>>> news B7EA3CA-F0A5-4586-A5F9-A625A0CF764C@xxxxxx>>>>>>>>I have a couple of .bas files and i need to use them in C#. I read >>>>>>>> Riquel_Dong reply that I need to compile them to COM dll files and >>>>>>>> use them. >>>>>>>> How do I compile .bas to dll? >>>>>>>> I saw another place: >>>>>>>> fbc -dll myfile.bas >>>>>>>> but its using freebasic and i could'nt understand it. Any other >>>>>>>> way. >>>>>>>> >>>>>>>> Sorry didnt know in which group to post. >>>>>>> >>>>>>> >>>>>> >>>>>> >>>>>> >>>>> >>>>> >>>> >>> >>> > |
