Vista - Power Point - Grouping tool greyed out
Old 04-14-2009   #1 (permalink)
alex r.
I have a group in a Power Point slide. I want to ungroup and change an
element. There is animation also applied to the slide. The "group" features
are greyed out when I select the group. Must I "unanimate" before it will
allow me to ungroup? If I unanimate, is there a "reanimate" selection that
will put it back EXACTLY as it was or do I need to redo the animation?
alex
Old 04-15-2009   #2 (permalink)
PvdG42
Re: Power Point - Grouping tool greyed out
"alex r." <arohall@xxxxxx> wrote in message
news:AB3BC96E-B5F1-4F9E-91E9-B8E6E2B0B591@xxxxxx
> features
> alex
As your question appears to be unrelated to .NET, I suggest that you ask in
a discussion group related to PowerPoint.
The group you want is:
microsoft.public.powerpoint
I'm cross posting this so the PowerPoint folks will see it.
Old 04-15-2009   #3 (permalink)
Lucy Thomson
"PvdG42" <pvdg@xxxxxx> wrote in message
news:e%23ox8ccvJHA.5836@xxxxxx
>> features
>> that
>> alex
> in a discussion group related to PowerPoint.
Thanks PvdG42 :-)
Alex - what version are you using? What do you want to change in the group?
What kind of animation does it have (i.e. why will reanimating be an issue).
Ungrouping does indeed get rid of the animation (but ungrouping may not be
necessary), and no there isn't a 're-animate' option, but there may be
workarounds if you tell us a little more.
Lucy
Lucy Thomson
PowerPoint MVP
MOS Master Instructor
www.aneasiertomorrow.com.au
Old 04-16-2009   #4 (permalink)
Echo S
In addition, I can't tell if the poster is trying to group or ungroup. You
cannot group placeholders (where it says, "click to add text" or "click to
add title" or "click to add picture" etc.), so if one of your selected
objects is a placeholder, this could be the problem.
Echo [MS PPT MVP] http://www.echosvoice.com
What's new in PPT 2007? http://www.echosvoice.com/2007.htm
Fixing PowerPoint Annoyances http://tinyurl.com/36grcd
PowerPoint 2007 Complete Makeover Kit http://tinyurl.com/32a7nx
"Lucy Thomson" <lucy@xxxxxx> wrote in message
news:e2%23xIzhvJHA.1748@xxxxxx
>>> features
>>> will
>>> that
>>> alex
> Thanks PvdG42 :-)
> group? What kind of animation does it have (i.e. why will reanimating be
> an issue). Ungrouping does indeed get rid of the animation (but ungrouping
> may not be necessary), and no there isn't a 're-animate' option, but there
> may be workarounds if you tell us a little more.
> Lucy
> Lucy Thomson
> PowerPoint MVP
Useful tool for power enthusiasts on the go (advanced power options) General Discussion
Power point Vista General
power point Vista General
Sleep option under power greyed out Vista performance & maintenance
Network, Volume and Power Greyed out on Notification Area Icons Vista General
