Vista - What are the disadvantages of unsafe build option when the codecontains no unsafe code? why is it not enabled by default?
Old 04-14-2009   #1 (permalink)
DR
What are the disadvantages of unsafe build option when the code contains
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Old 04-15-2009   #2 (permalink)
Cowboy \(Gregory A. Beamer\)
Re: What are the disadvantages of unsafe build option when the code contains no unsafe code? why is it not enabled by default?
The option just allows unsafe code to compile and does nothing else. There
is no safety issue if you have no unsafe code. And, I would imagine that the
worst with having it so you can compile unsafe code is you slow down the
compiler a few milliseconds, which is not a big deal.
Gregory A. Beamer
MVP; MCP: +I, SE, SD, DBA
Blog:
http://feeds.feedburner.com/GregoryBeamer
| Think outside the box |
"DR" <softwareengineer98037@xxxxxx> wrote in message
newsp.usd3urmzpe6dh9@xxxxxx
can't handle possible unsafe but in fact perfectly safe files Vista security
Pointer Option Default Vista General
windows mail has removed access to unsafe attachments Vista mail
Can we move files or is it 'unsafe'? Vista file management
Option for Default Hard Drive Vista General
