| | VS 2008 Setup Project, shortcut problem Hi all for our application we have a standard Visual Studio 2008 Setup Project. We noticed an annoyance: Administrator copies setup-files to his desktop and then installs the application for all users. the setup creates a icon on the desktop. now if the "normal" user clicks the icon the first time on his desktop, for some reason it seems to start setup.msi to check some things. and since the msi is still residing on the administrators desktop, of course the the normal user cannot start it, resulting in a error. workarround is to create the icon by hand or the admin installs from another folder then his own. i've unchecked "check for prerequisites" in the setup, doesn't help. any shortcut created in the setup project seems to launch the msi the first time it's clicked. any idea how to avoid this launch of the msi? is there a more appropriate newsgroup to ask this? (i didn't get an answer when i asked it last time) thank you! |
| | Re: VS 2008 Setup Project, shortcut problem Ty, Can you explain a little bit how you did it. Normally you simple use the Setup Wizard, takes the resulted shortcut to the screen and add in that the icon. Cor "Ty" <tylershome@xxxxxx> wrote in message news:daa5f74c-f902-4f62-a696-c8427b3a4396@xxxxxx Quote: > Hi all > > for our application we have a standard Visual Studio 2008 Setup > Project. We noticed an annoyance: > > Administrator copies setup-files to his desktop and then installs the > application for all users. the setup creates a icon on the desktop. > now if the "normal" user clicks the icon the first time on his > desktop, for some reason it seems to start setup.msi to check some > things. and since the msi is still residing on the administrators > desktop, of course the the normal user cannot start it, resulting in a > error. > > workarround is to create the icon by hand or the admin installs from > another folder then his own. > > i've unchecked "check for prerequisites" in the setup, doesn't help. > any shortcut created in > the setup project seems to launch the msi the first time it's clicked. > > any idea how to avoid this launch of the msi? > > is there a more appropriate newsgroup to ask this? (i didn't get an > answer when i asked it last time) > > thank you! |
| | Re: VS 2008 Setup Project, shortcut problem "Ty" <tylershome@xxxxxx> wrote in message news:daa5f74c-f902-4f62-a696-c8427b3a4396@xxxxxx Quote: > Hi all > > for our application we have a standard Visual Studio 2008 Setup > Project. We noticed an annoyance: > > Administrator copies setup-files to his desktop and then installs the > application for all users. the setup creates a icon on the desktop. > now if the "normal" user clicks the icon the first time on his > desktop, for some reason it seems to start setup.msi to check some > things. and since the msi is still residing on the administrators > desktop, of course the the normal user cannot start it, resulting in a > error. > > workarround is to create the icon by hand or the admin installs from > another folder then his own. > > i've unchecked "check for prerequisites" in the setup, doesn't help. > any shortcut created in > the setup project seems to launch the msi the first time it's clicked. > > any idea how to avoid this launch of the msi? > > is there a more appropriate newsgroup to ask this? (i didn't get an > answer when i asked it last time) > > thank you! Well, you previously posted this same text. You should have added that you then added the following: Quote: > Have you looked at the differences between the shortcut created manually > (after the install), versus what the installer creates? I believe you are > saying the manually created shortcut launches without issue. > > Probably a better group to ask this is "microsoft.public.dotnet.general", > but many posts there seem to be from users who have general hardware > questions... yes i checked that. there's a difference: Link created from setup: "Target" contains name of application, all greyed out. Link created manually: "Target" contains the actual path to the exe. not greyed out. no matter what file i link in the setup, the target contains only the application name. but it starts the correct file. so there's something going on behind the scene... So, I think the way you create the shortcut in your setup is not correct. Can you explain what you did in the setup project to create the shortcut? It sounds like you are not following the recommended procedure. -- Mike |
| | Re: VS 2008 Setup Project, shortcut problem Quote: Quote: > > Have you looked at the differences between the shortcut created manually > > (after the install), versus what the installer creates? I believe you are > > saying the manually created shortcut launches without issue. Quote: > > Probably a better group to ask this is "microsoft.public.dotnet.general", > > but many posts there seem to be from users who have general hardware > > questions... > yes i checked that. there's a difference: > > Link created from setup: "Target" contains name of application, all > greyed out. > Link created manually: "Target" contains the actual path to the exe. > not greyed out. > > *no matter what file i link in the setup, the target contains only the > application name. but it starts the correct file. so there's something > going on behind the scene... > > So, I think the way you create the shortcut in your setup is not correct. > Can you explain what you did in the setup project to create the shortcut? > It sounds like you are not following the recommended procedure. > > -- > Mike sorry about the missing info. In the setup i go to the FileSystem, choose "Primary output from...", then RightClick and then "Create Shortcut to Primary Output...". then i place the created shortcut in "User's Desktop" and "User's Programs Menu". that's about it... Thank you! |
| | Re: VS 2008 Setup Project, shortcut problem "Ty" <tylershome@xxxxxx> wrote in message news:1fd1a532-763e-447c-b5ef-660330d2eaac@xxxxxx Quote: > Hi Mike > > sorry about the missing info. > > In the setup i go to the FileSystem, choose "Primary output from...", > then RightClick and then "Create Shortcut to Primary Output...". then > i place the created shortcut in "User's Desktop" and "User's Programs > Menu". > > that's about it... > > Thank you! now, is this. I recall once "copying" the created icon to the desktop in the file system and seeing what you are observing. Look at the example link here. The steps are slightly different. http://www.codeproject.com/KB/dotnet...p_Project.aspx -- Mike |
| | #6 (permalink) |
| | Re: VS 2008 Setup Project, shortcut problem On 17 Apr., 21:53, "Family Tree Mike" <FamilyTreeM...@xxxxxx> wrote: Quote: > "Ty" <tylersh...@xxxxxx> wrote in message > > news:1fd1a532-763e-447c-b5ef-660330d2eaac@xxxxxx > Quote: > > Hi Mike Quote: > > sorry about the missing info. Quote: > > In the setup i go to the FileSystem, choose "Primary output from...", > > then RightClick and then "Create Shortcut to Primary Output...". then > > i place the created shortcut in "User's Desktop" and "User's Programs > > Menu". Quote: > > that's about it... Quote: > > Thank you! > The only thing that pops into my mind, as I only have express where I am > now, is this. *I recall once "copying" the created icon to the desktop in > the file system and seeing what you are observing. *Look at the examplelink > here. *The steps are slightly different. > > http://www.codeproject.com/KB/dotnet...p_Project.aspx > > -- > Mike This looks like VS2005. in 2008 there's no "Create New Shortcut". i'll have to investigate further. it's really strange that the "Target" is greyed out in these setup-created shortcuts. |
| | #7 (permalink) |
| | Re: VS 2008 Setup Project, shortcut problem On 21 Apr., 09:43, Ty <tylersh...@xxxxxx> wrote: Quote: > On 17 Apr., 21:53, "Family Tree Mike" > > > > <FamilyTreeM...@xxxxxx> wrote: Quote: > > "Ty" <tylersh...@xxxxxx> wrote in message Quote: > >news:1fd1a532-763e-447c-b5ef-660330d2eaac@xxxxxx Quote: Quote: > > > Hi Mike Quote: Quote: > > > sorry about the missing info. Quote: Quote: > > > In the setup i go to the FileSystem, choose "Primary output from...", > > > then RightClick and then "Create Shortcut to Primary Output...". then > > > i place the created shortcut in "User's Desktop" and "User's Programs > > > Menu". Quote: Quote: > > > that's about it... Quote: Quote: > > > Thank you! Quote: > > The only thing that pops into my mind, as I only have express where I am > > now, is this. *I recall once "copying" the created icon to the desktop in > > the file system and seeing what you are observing. *Look at the example link > > here. *The steps are slightly different. Quote: > > -- > > Mike > Hi Mike > > This looks like VS2005. in 2008 there's no "Create New Shortcut". > > i'll have to investigate further. it's really strange that the > "Target" is greyed out in these setup-created shortcuts. tried it using this: http://www.experts-exchange.com/Prog..._23833212.html but the effect is exaxtly the same. Target is greyed out and it's checking something if a new user clicks the icon... |
| Checking serial key with setup project. | .NET General | |||
| Empty Project in Visual Studio 2008 | .NET General | |||
| MSI Installer VS 2005 Setup Project | .NET General | |||
| Visual Studio 2008 Link Error for VS6.0 Project | .NET General | |||
| Advertised Shortcuts in a setup and deployment project | .NET General | |||
