| Vista Home Premium x64 | Hard Drive Help Hi Everyone, I am building a new system using Vista HP X64, I was going to use a WD 1TB hard drive but some reports state that these hard drives do not function with Vista x64.... ![]() Any advise????? |
| | Re: Hard Drive Help "ohoh7" <guest@xxxxxx-email.com> wrote in message news:637b09cc0ddcce2208e17c8c0ac0bf5a@xxxxxx-gateway.com... Quote: > > Hi Everyone, I am building a new system using Vista HP X64, I was going > to use a WD 1TB hard drive but some reports state that these hard drives > do not function with Vista x64.... ![]() > Any advise????? > > > -- > ohoh7 already have the drive, you're a WD customer and entitled to technical support. I'd consider it highly unlikely this is a Windows Vista issue, but if you wish to pursue your question in a Vista discussion group, here's how to find one. As you appear to be using a web interface, start here: http://www.microsoft.com/communities...s/default.aspx In the tree on the left, first open the English category, then open Windows. In Windows, find and open the category for Windows Vista. In that category, find a group to post in. |
| Vista Home Premium x64 | Re: Hard Drive Help Thanks PvdG42, No I haven't bought the HD yet, wanted to check before buying. I will follow your advice. Thanksomuch... ohoh7 |
| Hard drive light constantly flashing ,reading hard drive during id | Vista hardware & devices | |||
| Transfering from XP hard drive to vista Hard drive | Vista General | |||
| No online media available on new hard drive - old hard drive had l | Vista music pictures video | |||
| Crashed hard drive...copied hard drive but can't access User area | Vista General | |||
| Transferring files from Slave XP hard drive to new Vista Hard drive - primary | Vista installation & setup | |||
