| | Auto Numbering - SQL What is the sql standard code for auto numbering line items using a userstring? Thanks. Ex.: 1. 2. 3. etc... |
| | Re: Auto Numbering - SQL biz7 wrote: Quote: > What is the sql standard code for auto numbering line items using a > userstring? Thanks. > appear to have anything to do with .NET. Then again, it's hard to tell what your question *is*. Any of these things might be related: - IDENTITY columns: http://msdn.microsoft.com/library/ms186775 - ROW_NUMBER: http://msdn.microsoft.com/library/ms186734 - Sequence generation: http://groups.google.com/group/micro...1ffbb2536be508 -- J. |
| | Re: Auto Numbering - SQL biz, Auto numbering is not set by a user string as the subject of auto numbering is an integer, can you explain this a little bit more. The standard way of numbering his in by instance a datatable is -1 -2 -3 etc. Cor |
| Numbering | Vista General | |||
| Sequential File Name Numbering | Vista General | |||
| Word 2007 Automatic numbering for Table captions and Figure captio | Vista General | |||
| Vista Device numbering issue | Vista General | |||
| Photo numbering system in Vista | Vista music pictures video | |||
