Vista - MS Project 2003 - Global MPT
Old 04-22-2009   #1 (permalink)
Rowie
I was given a new PC at work (and both MS Project 2003 (SP2) and MS Project
2007 (SP1) installed). When I went to open my Project 03 files on my new PC
all of my Custom Views had disappeared (but not my custom tables or filters)?
I am also presently creating plans in 2007 (hence having both installed) but
didn't not have these errors on my old PC.
Could it be something to do with the way the Project software was installed?
Would installing SP3 on 2003 make a difference (although the last time I had
SP3 I had to uninstall it as it couldn't read my macros and crashed my
files). I tried logging on to somebody else's machine that has Project 2003
and my custom views were there?
Many Thanks
Rowie
Old 04-22-2009   #2 (permalink)
JS
Re: MS Project 2003 - Global MPT
If it's a new PC with a fresh install of MS Project,
then your customs views have not been migrated
from the old computer to your new one.
Read this on how to export:
http://blogs.msdn.com/teams_wit_tool...s-project.aspx
JS
http://www.pagestart.com
"Rowie" <Rowie@xxxxxx> wrote in message
news:FA9A43EF-E12B-4882-AB32-F8BECE678D53@xxxxxx
Quote:
> Hi,
> Project
> PC
> filters)?
> but
> installed?
> had
> 2003
> Many Thanks
> Rowie
Project 2003 Manipulation .NET General
Interop & Project 2003 .NET General
MSPS Project 2003 - Pink Icon .NET General
In any project, Can't we refer classes directly, (without addingphysically in the project)? .NET General
Compatibility with Office 2003/MS Project 2003 Vista General
