connectivite problem
  1. #1
    M Khan Guest
    2 days before when in morning iwe reach office then we found that our network
    ID is change from dhcp
    then i change DHCP confrigration again like old one but i m facing some
    problem
    from server i can ping all user but from user i can't ping server n i check
    all dns confrigration its ok all dhcp confrigration is ok but still don't
    know what wrong
    dhcp scoping ip confrigation is 192.168.10.20 to 192.168.10.90
    dafault gateway is 192.168.10.100 its firewell gateway
    server ip is 192.168.10.1
    so can any one plz give me the guideline i will be very greatfull
  2. #2
    PvdG42 Guest
    Re: connectivite problem
    "M Khan" <M Khan@xxxxxx> wrote in message
    news:5211698A-4F41-4AA3-8273-8F234C5A7CE1@xxxxxx
    > network
    > problem
    > check
    > know what wrong
    The "guideline" you need first is that your question needs to be asked in an
    appropriate discussion group for server issues. This is a .NET programming
    group.
    To find the group you need, do this:
    As you appear to be using a web interface, start here:
    http://www.microsoft.com/communities...s/default.aspx
    In the tree on the left, first open the English category, then open Servers.
    In Servers, find and open the category for Windows Server.
    In that category, find a group to post in.
the problem with ndis.sys Blue Screen of Death problem solved? liketofindoutwhy Vista General 6 24 May 2009
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Rainald Taesler Vista mail 14 17 May 2009
Generic McAfee Problem Message in Vista Problem Reports cyberbuff53 Vista performance & maintenance 0 01 Dec 2007
fixed unable to delete email problem, now I have new problem j2 Vista mail 19 29 Mar 2007
Vista Upgrade Problem - Windows Explorer Loop problem Steve S Vista installation & setup 0 27 Jun 2006
