| | Custom Control - OnPaint - not drawing Hi, I am trying to create a custom control in which I have to display my custom data. The custom control is placed on a form and docked completely. When I have the following code for the custom control, it doesn't re-paint all the data when I re-size the form vertically at run time. If I switch to other window and use ALT-TAB to switch back to my form, everything works fine. The code for my custom control is public partial class CustomControl1 : Control { Dictionary<int, string> data = new Dictionary<int, string>(); public CustomControl1() { InitializeComponent(); for (int i = 1; i <= 40; i++) { data[i * 20] = "This is a sample text for line number " + i.ToString(); } } protected override void OnPaint(PaintEventArgs e) { base.OnPaint(e); foreach (int y in data.Keys) { if (e.ClipRectangle.Y <= y && (e.ClipRectangle.Y + e.ClipRectangle.Height) >= y) { e.Graphics.DrawString(data[y], SystemFonts.DefaultFont, SystemBrushes.ControlText, new PointF(20, y)); } } } } I am actually confused with the the usage of ClipRectangle. Please advice. Thanks & Regards, Ashu |
| | RE: Custom Control - OnPaint - not drawing Hi Ashu, I notice you post the same issue in the microsoft.public.dotnet.languages.csharp newsgroup, in which I have replied. Please check my reply there. For your convenience, I include it here: ===================================== I performed a test on your sample code and did see the problem on my side. If you print out the value of the PaintEventArgs.ClipRectangle property from within the OnPaint method, you will see why the custom control doesn't re-paint all the data when the form is resized vertically at tun time. protected override void OnPaint(PaintEventArgs e) { base.OnPaint(e); // add this line of code to print the value of the ClipRectangle property to the Output window Console.WriteLine(e.ClipRectangle.ToString()); foreach (int y in data.Keys) { if (e.ClipRectangle.Y <= y && (e.ClipRectangle.Y + e.ClipRectangle.Height) >= y) { e.Graphics.DrawString(data[y], SystemFonts.DefaultFont, SystemBrushes.ControlText, new PointF(20, y)); } } } Press F5 to run the application and resize the form vertically. The values printed in the Output window are as follows: {X=0,Y=0,Width=419,Height=413} {X=0,Y=413,Width=419,Height=3} {X=0,Y=416,Width=419,Height=3} {X=0,Y=419,Width=419,Height=8} {X=0,Y=427,Width=419,Height=3} {X=0,Y=430,Width=419,Height=3} {X=0,Y=433,Width=419,Height=1} {X=0,Y=434,Width=419,Height=2} {X=0,Y=436,Width=419,Height=4} {X=0,Y=440,Width=419,Height=5} {X=0,Y=445,Width=419,Height=3} {X=0,Y=448,Width=419,Height=9} {X=0,Y=457,Width=419,Height=2} ... As you can see, the Paint event of the custom control is raised continously when I resize the form. Each time when the Paint event is raised, the PaintEventArgs.ClipRectangle is a small rectangle that doesn't meet the condition you set in the OnPaint method. Thus, the new strings are not drawn in the new rectangle on the custom control that needs painting. Use the ClientRectangle property of the custom control instead of the PaintEventArgs.ClipRectangle and this should solve your problem. For example: protected override void OnPaint(PaintEventArgs e) { base.OnPaint(e); foreach (int y in data.Keys) { if (this.ClientRectangle.Y <= y && (this.ClientRectangle.Y + this.ClientRectangle.Height) >= y) { e.Graphics.DrawString(data[y], SystemFonts.DefaultFont, SystemBrushes.ControlText, new PointF(20, y)); } } } ========================================== If you have any question, please reply to that thread and I will follow up with you in time. Have a nice day! Sincerely, Linda Liu Microsoft Online Community Support Delighting our customers is our #1 priority. We welcome your comments and suggestions about how we can improve the support we provide to you. Please feel free to let my manager know what you think of the level of service provided. You can send feedback directly to my manager at: msdnmg@xxxxxx. ================================================== Get notification to my posts through email? Please refer to http://msdn.microsoft.com/subscripti...ult.aspx#notif ications. Note: The MSDN Managed Newsgroup support offering is for non-urgent issues where an initial response from the community or a Microsoft Support Engineer within 1 business day is acceptable. Please note that each follow up response may take approximately 2 business days as the support professional working with you may need further investigation to reach the most efficient resolution. The offering is not appropriate for situations that require urgent, real-time or phone-based interactions or complex project analysis and dump analysis issues. Issues of this nature are best handled working with a dedicated Microsoft Support Engineer by contacting Microsoft Customer Support Services (CSS) at http://msdn.microsoft.com/subscripti...t/default.aspx. ================================================== This posting is provided "AS IS" with no warranties, and confers no rights. |
| | RE: Custom Control - OnPaint - not drawing Hi, Please ignore the post! The issue is resolved. I didn't consider the various cases of overlapping of clipping region and he drawing text. Thanks & Regards, Ashu |
| | RE: Custom Control - OnPaint - not drawing Hi, I did exactly the same just after posting the question...thanks anyways! But, you mentioned using ClientRectangle! I would not recommend that. It's totally un-necessary. Why do you want to paint an area which is already painted? Regards, Ashutosh |
| | RE: Custom Control - OnPaint - not drawing Hi Ashu, Thank you for your reply and I'm glad to hear that you have solved the problem. Quote: > But, you mentioned using ClientRectangle! I would not recommend that. already painted? Do you have any better option? Sincerely, Linda Liu Microsoft Online Community Support |
