| | System.Management.ManagementException 'generic failure' during remote WMI query Hi There I'm using a C# Visual Studio 2008 / .NET 3.5 / Windows Vista SP1 to write a utility that queries windows event log remotely. When querying a certain remote PC it works fine returning a couple of hundred events then suddenly an exception on this line. foreach (ManagementObject oReturn in oReturnCollection) (see below for context) It appears to be the same event log entry being read that causes this, because I am always getting the same event log entry before the exception. Is there anything I can do to detect the cause of this exception, or trap it (and continue the foreach loop?) The exception detail is System.Management.ManagementException was unhandled Message="Generic failure " Source="System.Management" StackTrace: at System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus errorCode) at System.Management.ManagementObjectCollection.ManagementObjectEnumerator.MoveNext() at EventAnalyzer.Program.Main(String[] args) in C:\Users\mccafma\Documents\Visual Studio 2008\Projects\EventAnalyzer\EventAnalyzer\Program.cs:line 387 at System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args) at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args) at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly() at System.Threading.ThreadHelper.ThreadStart_Context(Object state) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ThreadHelper.ThreadStart() InnerException: using System.Management; RemoteComputer = "remotepc01" bool display = true; ManagementScope oMs; ObjectQuery oQuery; ManagementObjectSearcher oSearcher; ManagementObjectCollection oReturnCollection; oMs=new ManagementScope(@"\\" + RemoteComputer + @"\root\cimv2", oConn); Query = "Select * from Win32_NTLogEvent Where (Logfile = 'System' OR Logfile='Application')"; //get system events oQuery = new ObjectQuery(Query); Console.WriteLine("Executing \"" + Query + "\" on " + oMs.Path.ToString()); Console.WriteLine(); //Execute the query oSearcher = new ManagementObjectSearcher(oMs, oQuery); //Get the results oReturnCollection = oSearcher.Get(); //loop through found drives and write out info foreach (ManagementObject oReturn in oReturnCollection) { // process items here } regards, Malcolm. |
| Disk Management Query Error | Vista General | |||
| startup failure & system restore 'WINRE' query | Vista performance & maintenance | |||
| Generic Failure on DFS WMI providers | PowerShell | |||
| Get-WmiObject : Generic failure | PowerShell | |||
| WMI DNS and 'Generic failure' | PowerShell | |||
