| | report viewer - project defined dataset Hello, i have the following issue: i setup a dataset in my project in order to use it for a report (report viewer control). with the wizard for a new report, i created "Dataset1". in the implementation that i found on internet, the programmer links a new dataset with the report before displaying the data. the dataset used for the report is then an other one than "Dataset1". But in my case, i want to use "Dataset1". but program says that it is empty. if i do a "preview data" with my "dataset1", i have rows ????? any idea ? thanks ELE |
| Reporting Services - Report Viewer webpart -- for MOSS on Vista | Vista General | |||
| Step Charts in Reports (RDLC - Report Viewer) | .NET General | |||
| MS Report viewer(RDLC) - Report from 2 tables without joins | .NET General | |||
| In any project, Can't we refer classes directly, (without addingphysically in the project)? | .NET General | |||
| Report Report !! Biggest Vista piracy website found !!! | Vista General | |||
