ahhh.... well not sure if it helped, but I see where you were trying to go
with this. Still exhibits the same behavior, but with a few more tests, this
is what I have determined. First, it always shows "new instance of visual
studio 2005" and "new instance of visual studio 2008" below. But, if I
actually open VS with a project, it says the same thing where the area for
"Test debuggers" is except it first shows the name of the project I have
open and then "new instance of visual studio (whichever versions I opened
the project in)". Please see attached pic regarding this. Any further help
any of you can come forth with please?
"Gloops" <gloops@xxxxxx> wrote in message
news:OSRdBSF3JHA.1432@xxxxxx
Hello,
As a command line, just type :
drwtsn32 -i
______________________________________
Mark G. a écrit, le 24/05/2009 10:29 :
> Am hoping this group can help as this does seem related to VS (Visual
> Studio" and the reactions with IE. I am using IE 7 and briefly installed
> Visual Studio 2010 beta and then uninstalled. I do have Visual Studio 2005
> and 2008 installed. Anyhow, since doing this, I get quite a few pop ups
> from
> "Visual Studio - Just In Time" debugger telling of an unhandled exception
> error in IE. It goes on to say "this object does not support this property
> or method". As if maybe I was writing code or something, but that is not
> the
> case while I have IE open. This happens on website/pages that I never had
> an
> issue with prior to installing and uninstalling the 2010 beta. Can any of
> you assist in figuring how to turn this off or figure out what happened
> and
> how to correct this please? I do have the "script debugging" turned off in
> my IE options. Any help is very much appreciated!
