Vista - Newbie - Help with a string
Old 06-02-2009   #1 (permalink)
Joey Martin
I am just trying to populate a HYPERLINK section and instead and it
linking to another window, I want to use javascript to open a window and
set a window size.
The first one just shows Click here and opens a windows. Perfect, except
I want to write some database results.
THIS WORKS
NavigateUrl="javascript:window.open('123.html',null, 'height=200,
width=400, status=yes, toolbar=no, menubar=no, location=no');
void('');"> click here</asp:HyperLink>
THIS DOES WORK ALSO-Note that I know have real text populating using
EVAL (KEYWORD LABEL).
NavigateUrl="javascript:window.open('123.html?catKeywords=',null,
'height=200, width=400, status=yes, toolbar=no, menubar=no,
location=no'); void('');"><%# Eval("KeywordLabel") %></asp:HyperLink>
THIS DOES NOT WORK. I want to write more variables that are passed into
the popup window.<%# Eval("KeywordLabel") %>
NavigateUrl="javascript:window.open('popsearch.asp?catKeywords=<%#
Eval("KeywordLabel") %>' height=200, width=400, status=yes, toolbar=no,
menubar=no, location=no'); void('');"> click here</asp:HyperLink>
Any ideas as to what I can do here???
THANK YOU SO MUCH IN ADVANCE!!!
*** Sent via Developersdex http://www.developersdex.com ***
Old 06-02-2009   #2 (permalink)
Andrew Morton
Re: Newbie - Help with a string
> and set a window size.
> into the popup window.<%# Eval("KeywordLabel") %>
> toolbar=no, menubar=no, location=no'); void('');"> click
You can set the url in the code-behind:
Hyperlink1.NavigateUrl=StringFormat("javascript:window.open('popsearch.asp?catKeywords={0}',height=200,width=400,status=yes,toolbar=no,menubar=no,
location=no);", Server.UrlEncode(KeywordLabel))
(Not tested: parentheses and quotes may not be balanced.)
Andrew
Old 06-02-2009   #3 (permalink)
Andrew Morton
And there's a dot missing from String.Format
Andrew
Old 06-02-2009   #4 (permalink)
Joey Martin
Ok, so what I am doing wrong here:
<asp:HyperLink ID="LnkPopSearch" runat="server"
NavigateUrl='<%#
string.Format("javascript:window.open('popsearch.asp?catKeywords={0}',nu
ll, 'height=200, width=400, status=yes, toolbar=no, menubar=no,
location=no');", Eval("KeywordsList")%>'><%# Eval("KeywordLabel")
%></asp:HyperLink>
Old 06-02-2009   #5 (permalink)
Andrew Morton
> NavigateUrl='<%#
> %></asp:HyperLink>
You're using <% %> inside an <asp> tag, which may or may not work depending
on which SP of which version of the framework you're using, i.e. it is
unreliable at best. Also, that isn't the code-behind.
http://en.wikipedia.org/wiki/Code-be...e-behind_model
It may at first appear to be simpler to put all the logic on the aspx page
along with the markup, but you will very quickly find it easier to use the
code-behind model.
HTH
Andrew
Find a string within a variable string PowerShell
problems with $var | select-string -pattern $string -q PowerShell
How export-csv deals with string versus string[] PowerShell
String PRODUCT_NAME was not found in string table Vista General
