Vista - System.ArgumentException in Environment.GetFolderPath
Old 06-03-2009   #1 (permalink)
Thorsten Prölß
Hello,
I have an issue using a typed dataset. Accessing the connection property of
the related TableAdapter, I get a System.ArgumentException.
The code does well on hundreds of pc's. Only on one customer pc we have this
specific issue. The affected machine has an Windows XP OS with .NET 2.0.
The exception:
Type: System.ArgumentException
Message:
Absolute path information is required.
Class: System.Security.Util.StringExpressionSet
Method: System.Collections.ArrayList
CreateListFromExpressions(System.String[], Boolean)
Assembly: mscorlib, Version=2.0.0.0, Culture=neutral,
PublicKeyToken=b77a5c561934e089
StackTrace:
at
System.Security.Util.StringExpressionSet.CreateListFromExpressions(String[]
str, Boolean needFullPath)
at
System.Security.Permissions.FileIOPermission.AddPathList(FileIOPermissionAccess
access, AccessControlActions control, String[] pathListOrig, Boolean
checkForDuplicates, Boolean needFullPath, Boolean copyPathList)
at
System.Security.Permissions.FileIOPermission..ctor(FileIOPermissionAccess
access, String path)
at System.Environment.GetFolderPath(SpecialFolder folder)
at System.Configuration.ClientConfigPaths..ctor(String exePath, Boolean
includeUserConfig)
at System.Configuration.ClientConfigPaths.GetPaths(String exePath,
Boolean includeUserConfig)
at
System.Configuration.Internal.ConfigurationManagerInternal.System.Configuration.Internal.IConfigurationManagerInternal.get_ExeProductName()
at System.Configuration.ApplicationSettingsBase.get_Initializer()
at
System.Configuration.ApplicationSettingsBase.CreateSetting(PropertyInfo
propInfo)
at System.Configuration.ApplicationSettingsBase.EnsureInitialized()
at System.Configuration.ApplicationSettingsBase.get_Properties()
at System.Configuration.SettingsBase.GetPropertyValueByName(String
propertyName)
at System.Configuration.SettingsBase.get_Item(String propertyName)
at System.Configuration.ApplicationSettingsBase.GetPropertyValue(String
propertyName)
at System.Configuration.ApplicationSettingsBase.get_Item(String
propertyName)
at Datev.Pegnitz.Properties.Settings.get_UAConnectionStringForDevelopment()
at
Datev.Pegnitz.Transfer.ProductTableAdapters.ProductsTableAdapter.get_Connection()
at
Datev.Pegnitz.DataAccess.DataManager.Datev.Pegnitz.DataAccess.IDataManager.GetProductsByDerivat(String licenseComponentId)
at Datev.Pegnitz.Business.ApplicationStartup.FillProductInformation()
I have made a demo exe and run it on the client's pc to enclose this
issue. The exe is a simple WinForm, with a button click calling
System.Environment.GetFolderPath(ApplicationData).
This call causes following exception:
ApplicationData
Exception:
Message:
Source
mscorlib
StackTrace
at
at
at
at Pfadermittlung.Form1.showFolders()
Calling GetFolderPath for all other values of Environment.SpecialFolder
(e.g. Programs, Desktop, MyDocuments ...) does work well.
Ok, it seems to be somthing wrong with the ApplicationData-path.
How can I find out what .Net thinks, the ApplicationData-Path is? Is there
a registry setting for this path?
Is this a security issu or is it an issue with syntactical wrong path
information like e.g. missing backslash between drive letter and folder path?
Thorsten
Old 06-05-2009   #2 (permalink)
Thorsten Prölß
RE: System.ArgumentException in Environment.GetFolderPath
Ok, we found the problem.
Changing the registry value
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell
Folders\AppData from O: to O:\ fixed this issue.
"Thorsten Prölß" wrote:
Quote:
> Hello,
> The exception:
> Message:
> StackTrace:
> at
> at
> at
> includeUserConfig)
> at
> at
> propInfo)
> propertyName)
> propertyName)
> propertyName)
> at
> at
> ApplicationData
> Exception:
> Message:
> Source
> mscorlib
> StackTrace
> at
> at
> at
> Thorsten
The system could not find the environment option that was entered Vista General
System.Environment.Commandline not available .NET General
Changing system environment variables Vista account administration
The system could not find the environment option that was entered Vista account administration
Environment.GetFolderPath returns wrong path .NET General
