Vista - Authentication error using WSHttpBinding in WCF
Old 06-04-2009   #1 (permalink)
cmac06
I have a WCF service that was using BasicHttpBinding, and was switched to
used WSHttpBinding. The service will work on Windows XP, but when moved the
Windows 2003 server/IIS 6, we are receiving the following error:
ServiceActivationException: The service
'/CJM4977/WCFServices/DataService.svc' cannot be activated due to an
exception during compilation. The exception message is: Security settings
for this service require 'Anonymous' Authentication but it is not enabled for
the IIS application that hosts this service..]
System.ServiceModel.AsyncResult.End(IAsyncResult result) +11531006
System.ServiceModel.Activation.HostedHttpRequestAsyncResult.End(IAsyncResult
result) +194
System.ServiceModel.Activation.HostedHttpRequestAsyncResult.ExecuteSynchronous(HttpApplication context, Boolean flowContext) +176
System.ServiceModel.Activation.HttpModule.ProcessRequest(Object sender,
EventArgs e) +278
System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +68
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean&
completedSynchronously) +75
The Web.config is set to only use Windows authentication.
authentication error Vista mail
Authentication Error Vista mail
Authentication error Vista installation & setup
