| | VB using WaitHandles I attempted to test how waithandles and autoresetevents work with one another in hopes to be able to use them in my application. However, I keep hitting the wall. Can some one look over the attached code and tell me what I am doing wrong. I am getting the following errors: C:\Development\Net\VB\TestThread\TestThread\bin>testthread Waiting for all current task to complete Task Id = 1 Sequence = 1 Task Run Id = 10 Task Mode = True Task Id = 2 Sequence = 1 Task Run Id = 10 Task Mode = True Task Id = 3 Sequence = 1 Task Run Id = 10 Task Mode = True Unhandled Exception: System.NullReferenceException: Object reference not set to an instance of an object. at System.Threading.WaitHandle.WaitMultiple(WaitHandle[] waitHandles, Int32 m illisecondsTimeout, Boolean exitContext, Boolean WaitAll) at System.Threading.WaitHandle.WaitAll(WaitHandle[] waitHandles, Int32 millis econdsTimeout, Boolean exitContext) at System.Threading.WaitHandle.WaitAll(WaitHandle[] waitHandles) at TestThread.TestThread.Main() in C:\Development\Net\VB\TestThread\TestThrea d\Module1.vb:line 48 What's odd about this is that I closely follows the example in Microsoft's MSDN web site. ' File: TestThread.vb Option Strict On Option Explicit On Imports System Imports System.Console Imports System.io Imports System.Threading Imports System.Threading.Thread Module TestThread Const MAXTASK As Integer = 5 Const MAXTHREAD As Integer = 25 <MTAThreadAttribute()> _ Sub Main() Dim Tasks As New ArrayList Dim RunTask As CTask Dim iRunTaskId As Integer = 10 Dim bRunTaskMode As Boolean = True Dim Sync(3) As AutoResetEvent 'Create an array used to define the task's Id and Sequence Dim TaskDefn(,) As Integer = New Integer(,) {{1, 1}, {2, 1}, {3, 1}, {4, 2}, {5, 3}} ' Create all the task using the TaskDefn array For i As Integer = 0 To MAXTASK - 1 Dim theTask As CTask = New CTask theTask.Id = TaskDefn(i, 0) theTask.Sequence = TaskDefn(i, 1) Tasks.Add(theTask) Next i Dim iSeq As Integer = 1000 Dim iTask As Integer = 0 For Each RunTask In Tasks If iSeq < RunTask.Sequence Then Console.WriteLine("Waiting for all current task to complete") WaitHandle.WaitAll(Sync) ' <<< THIS IS THE ERROR LINE Console.WriteLine("All task have completed") iTask = 0 End If iSeq = RunTask.Sequence Sync(iTask) = New AutoResetEvent(False) Dim TaskParam As New CTaskParam(RunTask, bRunTaskMode, iRunTaskId, Sync(iTask)) Try ThreadPool.QueueUserWorkItem(AddressOf cbStartProgram, TaskParam) Catch ex As Exception Console.WriteLine("Main Error Message: " + vbCrLf + ex.Message) End Try iTask += iTask Next Sleep(3000) End Sub Class CTaskParam Public Task As CTask Public Mode As Boolean Public RunId As Integer Public SignalWhenDone As AutoResetEvent Sub New(ByVal TaskParam As CTask, ByVal ModeParam As Boolean, ByVal RunIdParam As Integer, ByVal SignalParam As AutoResetEvent) Me.Task = TaskParam Me.Mode = ModeParam Me.RunId = RunIdParam Me.SignalWhenDone = SignalParam End Sub End Class ' This module represent an intermediary module used to create a thread and process ' the parameters, eventually invokeing the actual object/module Sub cbStartProgram(ByVal theTaskParam As Object) ' Get the arguments Dim TaskParam As CTaskParam = CType(theTaskParam, CTaskParam) Try ' Invoke the object TaskParam.Task.Run(TaskParam.RunId, TaskParam.Mode) Catch ex As Exception Console.WriteLine("Start Program - Error Message: " + vbCrLf + ex.Message) Finally TaskParam.SignalWhenDone.Set() End Try End Sub End Module ' This Class represents any task that can be call from .Net ' Class CTask Dim iSequence As Integer Dim iId As Integer Property Sequence() As Integer Get Return iSequence End Get Set(ByVal Value As Integer) iSequence = Value End Set End Property Property Id() As Integer Get Return iId End Get Set(ByVal Value As Integer) iId = Value End Set End Property Sub Run(ByVal iTaskRunId As Int32, ByVal bTaskMode As Boolean) Console.WriteLine("Task Id = " + Id.ToString + " Sequence = " + Sequence.ToString) Console.WriteLine("Task Run Id = " + iTaskRunId.ToString + " Task Mode = " + bTaskMode.ToString) Console.WriteLine() Return End Sub End Class |
