| | Problems formating date I try to format a date using following myDateTime.ToString("dd/MM/yyyy") Which I assumed would give me a date seperated by slashed, but it gives me the date using '-'. Can anyone tell me what I am doing wrong? I export to csv and the goal is to let the user be able specify the date formating. TIA Soeren D. |
| | Re: Problems formating date "Søren D" <null@xxxxxx> schreef in bericht news:uyot$5S6JHA.1416@xxxxxx Quote: >I try to format a date using following > > myDateTime.ToString("dd/MM/yyyy") > > Which I assumed would give me a date seperated by slashed, but it gives me > the date using '-'. > > Can anyone tell me what I am doing wrong? I export to csv and the goal is > to let the user be able specify the date formating. > > TIA > > Soeren D. From the .net framework help file: / Represents the date separator defined in the current DateTimeFormatInfo.DateSeparator property. ' Represents a quoted string (apostrophe). Displays the literal value of any string between two apostrophe (') characters. In your case, the '/' is translated to a '-' because in your system, the current date seperator is a '-'. So you need to use a literal value: myDateTime.ToString("dd'/'MM'/'yyyy"); or: mySeperator = "/"; myDateTime.ToString("dd'"+mySeperator+"'MM'"+mySeperator+"'yyyy"); regards, Marcel |
| Date problems in MS-DOS program | Vista installation & setup | |||
| Date format problems after applying Vista SP1 | Vista General | |||
| What problems have you had to date with Vista? | General Discussion | |||
| Date problems in PS | PowerShell | |||
| Date/Time Reset Problems | Vista General | |||
