Vista - 'unmountable_boot_volume' how can i fix this without origional OS
Old 06-12-2009   #1 (permalink)
darylrose
basically, what it says in the title. my computer is BSOD with error
'unmountable_boot_volume'. i know i can fix this by going into the recovery
console on the OS CD supplied with the computer but i accidentally
dropped/stepped on the cd and it broke into several pieces.
i need solution fast as i have data on there i need for work quite urgently.
any help is great, thanks, Daryl.
Old 06-12-2009   #2 (permalink)
PvdG42
Re: 'unmountable_boot_volume' how can i fix this without origional OS
"darylrose" <darylrose@xxxxxx> wrote in message
news:170589A2-D97F-40D2-B09B-31545A098B92@xxxxxx
> recovery
> urgently.
Some possible quick fixes:
1. Work computer? Borrow the recovery media from somebody with the same
make/model.
2. Contact the manufacturer for a way to download the recovery image.
3. Remove hard drive from your computer and attach it to a different
computer to copy the needed files for access.
UNMOUNTABLE_BOOT_VOLUME IN VISTA! Vista General
blue screen - 0x000000ED (UNMOUNTABLE_BOOT_VOLUME) General Discussion
Unmountable_boot_volume Vista General
Unmountable_boot_volume General Discussion
Vista Upgrade unmountable_boot_volume issue Vista installation & setup
