| | problem with data access?!?!?! Hi Al I was getting an error: Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.ArgumentException: Keyword not supported: 'provider' with the line 21 which is just SqlDataSource and the connstring int the web.config is: <add name="BOConnectionString" connectionString="Provider=SQLOLEDB;Data Source=msqlserver.scs.sk.ca;Integrated Security=SSPI;Initial Catalog=matbrdoff"/> <add name="BOServerString" connectionString="msqlserver.here.ca"/> any ideas what might be stopping me here ? Sub btnTest_Click(Sender As Object, E As EventArgs) Dim SqlDatasource1 As New SqlDataSource Dim stnum As Long Dim test, test2, cnt As Integer Dim strBOConnection As String = ConfigurationManager.ConnectionStrings ("BOConnectionString").ConnectionString lblMessage.Text = strBOConnection stop SqlDataSource1.ConnectionString = strBOConnection SqlDataSource1.UpdateCommand = "update divassessment set term = null,aterm= 0,final=null,afinal = 0 where subjectcode = 'RR' and grade = '2' and year = '2009'" SqlDataSource1.Update() <--- System.ArgumentException: Keyword not supported: 'provider'. |
| Opinion on XML data access | .NET General | |||
| USB Flash Disk access problem; Vital Data at Stake =[ | Vista hardware & devices | |||
| How to access encryptise data | Vista General | |||
| Vista can't access USB data | Vista General | |||
| Data Access | Vista installation & setup | |||
