| Guest | 32 bit activex on IE 64 bit- Window Vista x64. Hi I have an 32 bit activex control which is not working on IE 64 bit -Vista x64 and working good on IE 32 bit -Visat x64 and this activex is developed in VB6 using another third pary 32 bit activex control and i am getting the following error in temparary internet files. *** Code Download Log entry (23 Jun 2009 @ 17:27:29) *** Code Download Error: (hr = 8007007e) The specified module could not be found. Operation failed. Detailed Information: CodeBase: CLSID: {27AB0257-66AC-4AB3-9001-48D637076139} Extension: Type: LOG: Reporting Code Download Completion: (hr:8007007e (FAILED), CLASSID: 27ab0257..., szCODE (null)), MainType null), MainExt null))--- Detailed Error Log Follows --- LOG: Download OnStopBinding called (hrStatus = 800c0007 / hrResponseHdr = 8007007e). LOG: Redundant download attempted, but no more codebases available. LOG: URL Download Complete: hrStatus:800c0007, hrOSB:0, hrResponseHdr:8007007e, URL http://activex.microsoft.com/objects/ocget.dll)LOG: Reporting Code Download Completion: (hr:8007007e (FAILED), CLASSID: 27ab0257..., szCODE (null)), MainType null), MainExt null)) |
| Guest | Re: 32 bit activex on IE 64 bit- Window Vista x64. "sanjay.nandgowli@xxxxxx" <sanjay.nandgowli@xxxxxx@discussions.microsoft.com> wrote in message news:F031D08E-71E5-4520-AF95-87B5CA9DA7F0@xxxxxx Quote: > Hi > I have an 32 bit activex control which is not working on IE 64 bit -Vista > x64 and working good on IE 32 bit -Visat x64 and this activex is developed > in > VB6 using another third pary 32 bit activex control and i am getting the > following error in temparary internet files. > > *** Code Download Log entry (23 Jun 2009 @ 17:27:29) *** > Code Download Error: (hr = 8007007e) The specified module could not be > found. > > Operation failed. Detailed Information: > CodeBase: > CLSID: {27AB0257-66AC-4AB3-9001-48D637076139} > Extension: > Type: > > LOG: Reporting Code Download Completion: (hr:8007007e (FAILED), CLASSID: > 27ab0257..., szCODE (null)), MainType null), MainExt null))> --- Detailed Error Log Follows --- > LOG: Download OnStopBinding called (hrStatus = 800c0007 / hrResponseHdr = > 8007007e). > LOG: Redundant download attempted, but no more codebases available. > LOG: URL Download Complete: hrStatus:800c0007, hrOSB:0, > hrResponseHdr:8007007e, > URL http://activex.microsoft.com/objects/ocget.dll)> LOG: Reporting Code Download Completion: (hr:8007007e (FAILED), CLASSID: > 27ab0257..., szCODE (null)), MainType null), MainExt null))> > > Try building your executable for "x86" rather than for "Any CPU". You cannot mix 32 and 64 bit components. -- Mike |
| Vista needs ActiveX | General Discussion | |||
| Vista and ActiveX controls | Vista performance & maintenance | |||
| How do you register an ActiveX EXE on Vista? | Vista General | |||
| How do you register an ActiveX EXE on Vista? | Vista security | |||
| ActiveX Control prompt "An ActiveX control on this page might be u | Vista General | |||
