| Guest | X P pro Start up/boot down Problems Hello, For 1 month I have had a niggling problem on this PC.I have X P Pro ,using IE8 When using start up,I get the usual run of windows start up checks,all perfectly o k.,but then I get a period of black screen which usually lasts about 3 mins before the normal Xp logo appears, it then carries on as normal This also happens at close down,after using the "CLOSE DOWN " button I then get a black screen before actual shut off.I have run anti virus(brand new)I have run SpyBot,and anti Malware programs with no effect. Any advise please, Thanks -- doulton |
| Guest | Re: X P pro Start up/boot down Problems "doulton" <doulton@xxxxxx> wrote in message news:8B04656C-7605-4016-B952-A14B1A748762@xxxxxx Quote: > Hello, > For 1 month I have had a niggling problem on this PC.I have X P Pro ,using > IE8 When using start up,I get the usual run of windows start up checks,all > perfectly o k.,but then I get a period of black screen which usually lasts > about 3 mins before the normal Xp logo appears, it then carries on as > normal > This also happens at close down,after using the "CLOSE DOWN " button I > then > get a black screen before actual shut off.I have run anti virus(brand > new)I > have run SpyBot,and anti Malware programs with no effect. > Any advise please, > Thanks > -- > doulton discussion group and not in this .NET programming group. As you appear to be using a web interface, try this: http://www.microsoft.com/communities/newsgroups/en-us/ In the tree on the left, open English, then open Windows. In the Windows subcategory, find and open the subcategory for Windows XP, and find a group there for your post. |
| VIsta The following boot-start or system-start driver(s) failed to load: | Drivers | |||
| laptop start up problems and problems in general | General Discussion | |||
| start up/boot problems | Vista General | |||
| Weirdest problems.Can't start programs from start menu and use Cop | Vista General | |||
| XP/Vista dual boot XP won't start from Vista boot manager | Vista installation & setup | |||
