Vista - progress indicator initial page load ajax not working use javascript?
Old 07-08-2009   #1 (permalink)
CMELLO
I am using Ajax panels to show progress when a button inside an update
panel executes a procedure “Chart2_Load” to fill a chart also inside
an update panel. It works the progress panel behaves correctly.
When the page loads initially the chart is filled with a default
values and the progress bar does not show during the initial page
load, this is also the longest time to wait for the load.
protected void Page_Load(object sender, EventArgs e)
if (!(Page.IsPostBack))
Chart2_Load(TextStart, TextEnd);
How can I show simple waiting message with Javascript or tell me what
I am doing wrong with Ajax to get the progress panel to display during
the first page load seen above? Progress panel is NOT associated with
a specific update panel.
I have included the html for the panels below.
User requirements are to load the page initial with default values and
not ask them to click before chart loads first time.
<html xmlns="http://www.w3.org/1999/xhtml" >
<head runat="server">
<style type="text/css">……..
</style>
</head>
<body>
<form id="form1" runat="server">
<asp:ScriptManager ID="ScriptManager1" runat="server" />
<asp:UpdatePanel ID="QuarterUpdatePanel" runat="server"
ChildrenAsTriggers="true" UpdateMode="Always">
<ContentTemplate>
<aspataList id="dlButtons runat="server" />
</ContentTemplate>
</asp:UpdatePanel>
<asp:UpdatePanel ID="PieUpdatePanel" runat="server"
OnLoad="PieUpdatePanel_Load" ChildrenAsTriggers="true"
<ContentTemplate>
<dotnet:Chart id="ChartPie" runat="server"/>
</ContentTemplate>
</asp:UpdatePanel>
<asp:UpdateProgress ID="UpdateProgress1" runat="server"
<ProgressTemplate>
<div id="OuterTableCellOverlay">
<div id="InnerTableCellOverlay">
<b>... LOADING ...</b>
<asp:Image ID="LoadImage" runat="server"
ImageUrl="~/Images/ajax-loader.gif" />
</div>
</div>
</ProgressTemplate>
</asp:UpdateProgress>
<asp:UpdatePanel ID="ChartUpdatePanel" runat="server"
OnLoad="ChartUpdatePanel_Load">
<ContentTemplate>
<dotnet:Chart id="Chart5" runat="server"/>
</ContentTemplate>
</asp:UpdatePanel>
</form>
</body>
</html>
Windows Update Won't Load--gets error-"This page failed to load" Windows Updates
ASP.NET ajax client side framework failed to load .NET General
Javascript not working in Windows Vista Vista General
JavaScript on IE Stopped Working Vista General
Vista 64 Install Fails just after initial file load Vista installation & setup
