| | ContextMenu Does Not Work? Why doesn't the following sample code work? The click event never seems to fire for the menu items. Similar code works for the ContextMenuStrip class but I need the modal nature of ContextMenu. private void ShowContextMenu() { using (ContextMenu menu = new ContextMenu()) { menu.MenuItems.Add("Test1", new EventHandler(MenuItemClicked)); menu.MenuItems.Add("Test2", new EventHandler(MenuItemClicked)); menu.MenuItems.Add("Test3", new EventHandler(MenuItemClicked)); menu.Show(this, new Point(0, 0)); } } private void MenuItemClicked(object sender, EventArgs e) { MenuItem item = (MenuItem)sender; MessageBox.Show(item.Text); } |
| making entry to contextmenu using registry | General Discussion | |||
| HP LaserJet 1010 don't work in Vista since Beta2 - Advanced 1384 Printing Support drivers for XP don't work | Vista print fax & scan | |||
