Vista - Question about bit shift
Old 07-15-2009   #1 (permalink)
Mars Shi
I have some special requirements on bit shift by vb.net.
- I want to know how to get the shifted bit value.
- I want to know how to make shifted bit to another variable.
Suppose, I have two variables, byteA is &H0, byteB is &H8F
For the 1st question, if I left shift byteB, like byteB << 1, byteB will
be 00011110 (&H1E), but I want to get the bit being shifted, which is 1,
please tell me how I could get it.
For the 2nd question, I wish the shifted bit from byteB could be shifted
into byteA. The result I want is that, after operation, byteA would be
&H01, and byteB would be &H1E.
Also I wish variables could be byte, integer or long.
Is there any simple operator from VB.net?
Thanks
Mars
Old 07-16-2009   #2 (permalink)
Morten Wennevik [C# MVP]
RE: Question about bit shift
Hi Mars
Regarding the first question, ALL bites get shifted one position left, but I
assume you mean which bits fall outside.
&H8F = 10001111
10001111 << 1 = 00011110
Well, since bit shifting is actually a 32 bit operation you end up with
00000000 00000000 00000001 00011110
compared to a byte you get the bits shifted by right shifting 8
00000000 00000000 00000001 00011110 >> 8
00000000 00000000 00000000 00000001
In C# you actually get a compiler error if you try to store the shifted
result in a byte.
byte b = 0x8F;
int c = b << 1; // = 0x11E
In VB the compiler will cast the result to the type of b, which means you
will lose the shifted bits. I believe you will need to define b as an
Integer to get the result as an Integer
Dim byteB As Integer = &H8F
Dim byteC = byteB << 1 ' = &H11E
Anyhow, if the bits shifted left falls outside you need to store them before
you shift. You can easily find them by shifting the original value 8 - #
places right in case you shift a byte, 16 - # for short and 32 - # for
integer, and 64 - # for long.
Dim byteShifted = byteB >> (8 - 1)
Happy Coding!
"Mars Shi" wrote:
Quote:
> Hi,
> Thanks
> Mars
Need For Speed Shift Gaming
SHIFT KEY OUT OF CONTROL Vista General
shift of view Vista General
shift key problems Vista General
Eratic shift key Vista General
