| VistaHome | Link to Sql - Problems on Updating Database Hello Everyone, I'm quite new to Linq and have had some problems updating my dabase. I don't know if it is actually happening for be using a global data context or I'm missing something. I have my typed DataContex and one Static Public Var to initialize it located within the namespace AlpaCommon, like following: ***********************My partial datacontext******************* // partial datacontext class namespace AlpaCommon { public partial class AlpaDataContext : System.Data.Linq.DataContext { //Insert method is working... public void InsertAnimal2(Animal instance) { Animais.InsertOnSubmit(instance); SubmitChanges(); } //Delete method is working... public void DeleteAnimal2(int animalID) { var animal = (from a in Animais where a.AnimalID == animalID select a).First(); Animais.DeleteOnSubmit(animal); SubmitChanges(); } //Update method IS NOT working... public void UpdateAnimal2(Animal newAnimal) { var animal = (from a in Animais where a.AnimalID == newAnimal.AnimalID select a).First(); animal = newAnimal; SubmitChanges(); } *****This is where I'm instanciating the datacontext e other variables I'll need in the whole app*** //global DataContext instance namespace AlpaCommon { public static class Globals { public static AlpaDataContext db = new AlpaDataContext(); ******************* This is the call to the update method ************** .................... .................... using AlpaCommon; namespace Animais { public partial class Altera : System.Web.UI.Page { .................... .................... .................... .................... protected void btnUpdate_Click(object sender, EventArgs e) { try { //cria um novo Objeto do tipo Animal Animal animalAltera = new Animal(); //set new values animalAltera.AnimalID = Convert.ToInt32(Request.Params["AnimalID"]); animalAltera.Castrado = CastradoCheckBox.Checked; animalAltera.DisponivelAdocao = DisponivelCheckBox.Checked; animalAltera.Adotado = AdotadoCheckBox.Checked; animalAltera.Nome = NomeTextBox.Text; animalAltera.Tipo = TipoDropDownList.SelectedValue; animalAltera.Sexo = SexoDropDownList.SelectedValue; animalAltera.Descricao = DescricaoTextBox.Text; animalAltera.Local = LocalTextBox.Text; animalAltera.Foto = AlteraFoto(); AlpaCommon.Globals.db.UpdateAnimal2(animalAltera); redirect = redirectSucesso; } catch { redirect = redirectErro; } finally { Helper.Redirect(redirect); } } ****************************************************************************************** I'm not catching any exception, it just does not update the database. Am I missing something in my updating or calling method? I'm looking forward for suggestions. Thank you Josimari Martarelli |
| Some problems after updating... | Vista General | |||
| Vista updating problems | Vista installation & setup | |||
| Works database 2007 and Office database 2003 | .NET General | |||
| Wireless Vista problems after updating | Vista General | |||
| Problems with Updating in Vista | Vista General | |||
