Vista - Setting properties on hosted toolstrip control at design time
Old 07-30-2009   #1 (permalink)
Mike
I created my own toolstrip control using ToolStripControlHost. When I
add this to a toolstrip, I want to adjust the properties of the hosted
control in the designer but they always get reset when I compile. Can
anyone tell me how to fix this? This should be similar to accessing
the panels in a SplitContainer control so I think it is possible.
Here is some *sample* code to illustrate the problem.
[ToolStripItemDesignerAvailability
(ToolStripItemDesignerAvailability.ToolStrip |
ToolStripItemDesignerAvailability.StatusStrip)]
public class ToolStripHostExample : ToolStripControlHost
public TextBox MyControl
get { return (TextBox)Control; }
public ToolStripHostExample() : base(new TextBox())
Add it to a toolstrip and try to set the MyControl.ReadOnly attribute
to true in the designer. When you compile, the property will be reset
to false.
Old 07-31-2009   #2 (permalink)
Mike
Re: Setting properties on hosted toolstrip control at design time
For anyone else struggling with a similar problem, I found the
solution by taking a closer look at the panels in theSplitContainer
control.
Adding the DesignerSerializationVisibility attribute to the MyControl
property in my sample code solves the problem. Here is the fixed
sample code...
[DesignerSerializationVisibility
(DesignerSerializationVisibility.Content)]
> * public TextBox MyControl
> * * get { return (TextBox)Control; }
> * public ToolStripHostExample() : base(new TextBox())
> to false.
Can't read appSettings of IE hosted control when under SSL .NET General
Security questions around browser hosted control interaction. .NET General
Re: Problem running .NET user control hosted on Windows Vista / IE 7 Vista security
