| | How to copy text from webbrowser/Frame Control (WPF) Hello, I've added a webbroswer control in my WPF application, As the app loads up, it naviagates to a site then How do I copy text from the site using code. I can successfully do this in WinForms using WebBrowser1.Document.DomDocument not able to do the same in WPF webbrowser control. Any tips. Thanks in Advance! Regards, Claton |
| | Re: How to copy text from webbrowser/Frame Control (WPF) The document should be available in the WebBrowser object. There's a property named Document. http://msdn.microsoft.com/en-us/libr...r_members.aspx -- regards Bjarte Skogøy "claton" <claton@xxxxxx> skrev i nyhetsmeldingen: BE05FA45-B854-4032-8524-2CCF499CA176@xxxxxx ... Quote: > Hello, > > I've added a webbroswer control in my WPF application, As the app loads > up, > it naviagates to a site then How do I copy text from the site using code. > I > can successfully do this in WinForms using > WebBrowser1.Document.DomDocument > not able to do the same in WPF webbrowser control. > Any tips. > > Thanks in Advance! > > Regards, > Claton > > |
| | Re: How to copy text from webbrowser/Frame Control (WPF) Thank you Bjarte for replying, I have checked the msdn and the property document is a bit different than the WinForm WebBrowser. I have the following code in Winform Public Class Form1 Dim doc As mshtml.HTMLDocument Dim txtRange As mshtml.IHTMLTxtRange Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load WebBrowser1.Navigate("www.microsoft.com") End Sub Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click txtRange = doc.selection.createRange() MessageBox.Show(txtRange.text.ToString()) End Sub Private Sub WebBrowser1_DocumentCompleted(ByVal sender As Object, ByVal e As System.Windows.Forms.WebBrowserDocumentCompletedEventArgs) Handles WebBrowser1.DocumentCompleted doc = Me.WebBrowser1.Document.DomDocument End Sub End Class ------------------ but when I try to use the WPF webbrowser it does not have extented properties to the Document just like the winForm Document.DomDocument. - Claton "Bjarte Skogøy" wrote: Quote: > The document should be available in the WebBrowser object. There's a > property named Document. > http://msdn.microsoft.com/en-us/libr...r_members.aspx > > > -- > regards > Bjarte Skogøy > > "claton" <claton@xxxxxx> skrev i nyhetsmeldingen: > BE05FA45-B854-4032-8524-2CCF499CA176@xxxxxx ... Quote: > > Hello, > > > > I've added a webbroswer control in my WPF application, As the app loads > > up, > > it naviagates to a site then How do I copy text from the site using code. > > I > > can successfully do this in WinForms using > > WebBrowser1.Document.DomDocument > > not able to do the same in WPF webbrowser control. > > Any tips. > > > > Thanks in Advance! > > > > Regards, > > Claton > > > > |
| | Re: How to copy text from webbrowser/Frame Control (WPF) okie! I found the answer here http://www.rhizohm.net/irhetoric/blog/72/default.aspx you need to type cast MSHTML to the webbrowser.document so access the contents/text on the navigated URL. Hope this helps others too.. ~ Claton "claton" wrote: Quote: > Thank you Bjarte for replying, > I have checked the msdn and the property document is a bit different than > the WinForm WebBrowser. I have the following code in Winform > > Public Class Form1 > Dim doc As mshtml.HTMLDocument > Dim txtRange As mshtml.IHTMLTxtRange > Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As > System.EventArgs) Handles MyBase.Load > WebBrowser1.Navigate("www.microsoft.com") > End Sub > > Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As > System.EventArgs) Handles Button1.Click > txtRange = doc.selection.createRange() > MessageBox.Show(txtRange.text.ToString()) > End Sub > > Private Sub WebBrowser1_DocumentCompleted(ByVal sender As Object, ByVal > e As System.Windows.Forms.WebBrowserDocumentCompletedEventArgs) Handles > WebBrowser1.DocumentCompleted > doc = Me.WebBrowser1.Document.DomDocument > End Sub > End Class > ------------------ > but when I try to use the WPF webbrowser it does not have extented > properties to the Document just like the winForm Document.DomDocument. > > - Claton > > "Bjarte Skogøy" wrote: > Quote: > > The document should be available in the WebBrowser object. There's a > > property named Document. > > http://msdn.microsoft.com/en-us/libr...r_members.aspx > > > > > > -- > > regards > > Bjarte Skogøy > > > > "claton" <claton@xxxxxx> skrev i nyhetsmeldingen: > > BE05FA45-B854-4032-8524-2CCF499CA176@xxxxxx ... Quote: > > > Hello, > > > > > > I've added a webbroswer control in my WPF application, As the app loads > > > up, > > > it naviagates to a site then How do I copy text from the site using code. > > > I > > > can successfully do this in WinForms using > > > WebBrowser1.Document.DomDocument > > > not able to do the same in WPF webbrowser control. > > > Any tips. > > > > > > Thanks in Advance! > > > > > > Regards, > > > Claton > > > > > > |
| How do I debug JavaScript in a WebBrowser control? | .NET General | |||
| automating ie or webbrowser control | VB Script | |||
| is the dotnet 2 webbrowser control based on IE 6 or 7? | .NET General | |||
| Printint the content of a webbrowser control | .NET General | |||
