Vista - NegotiateStream delegation problem
Old 08-13-2009   #1 (permalink)
DAXU
Hello,
I have following code from client: (it is just a test app)
using (
System.Security.Principal.WindowsImpersonationContext wic =
System.Security.Principal.WindowsIdentity.GetCurrent().Impersonate())
System.Net.ICredentials creds =
System.Net.CredentialCache.DefaultCredentials;
// need a full duplex stream - loopback is easiest
way to get that
using (NegotiateStream clientSide = new
NegotiateStream(new TcpClient(server,
port).GetStream()))
clientSide.AuthenticateAsClient
(System.Net.CredentialCache.DefaultNetworkCredentials,
"", ProtectionLevel.EncryptAndSign,
TokenImpersonationLevel.Delegation);
Server side has SPN set and active directory attributes set and has
the same settings as client (encryptandsign and require delegation),
but when I run it, I got this error:
The client side:
A remote side security requirement was not fulfilled during
authentication. Try increasing the ProtectionLevel and/or
ImpersonationLevel.
The server side error is:
A security requirement was not fulfilled during authentication.
Required: Delegation, negotiated: Impersonation.
If I change the ImpersonationLevel to impersonate, no error will be
thrown out. I suspect it is because I use
System.Security.Principal.WindowsIdentity.GetCurrent().Impersonate(),
instead of using username and password to do a logon. But I really
want to just use windowsIdentity to achieve delegation, as delegation
will be definitely required. Is it possible and can someone give me
some help?
Many Thanks
Jerry
NegotiateStream.AuthenticateAsClient problem? .NET General
Re: CredSSP and kerberos credentials delegation Vista security
RDP/TS Single-sign-on with credentails delegation Vista security
SQL + IIS Delegation woes .NET General
View delegation permissions of OU PowerShell
