RB
Vista - Is it possible to define two separate "Sort" methods in the sameclass?
08-14-2009   #1
Curious
I have two ArrayLists:
ArrayList mBuyLimits = new ArrayList();
ArrayList mSellLimits = new ArrayList();
Each item on mBuyLimits and mSellLimits is an instance of
"LongTermLimit" that is defined as below:
public class LongTermLimit
protected double mPrice;
protected int mShares;
public LongTermLimit(double price, int shares)
mPrice = price;
mShares = shares;
public double Price
get { return mPrice; }
public int Shares
set { mShares = value; }
get { return mShares; }
For mBuyLimits, I want to sort it by "Price" in descending order. For
instance, if mBuyLimits contains the following:
Shares Price
300 25.04
230 26.04
470 26.6
I want to sort it to:
Shares Price
470 26.6
230 26.04
300 25.04
For mSellLimits, I want to sort it by "Price" in ascending order. For
instance, if mSellLimits contains the following:
Shares Price
300 49.58
230 46.2
100 36.04
130 39.42
170 42.81
Shares Price
100 36.04
130 39.42
170 42.81
230 46.2
300 49.58
Is there a way to define two separate "Sort" methods in the class,
"LongTermLimit". One is for sorting by "Price" in descending order
(for sorting mBuyLimits), and the other one is for sorting by "Price"
in ascending order (for sorting mSellLimits)?
08-14-2009   #2
PvdG42
Re: Is it possible to define two separate "Sort" methods in the same class?
"Curious" <fir5tsight@xxxxxx> wrote in message
news:11bd8a8d-8c31-400f-9f87-1ecc9861ae87@xxxxxx
> mPrice = price;
> mShares = shares;
> public double Price
> public int Shares
> Shares Price
> 300 25.04
> 230 26.04
> 470 26.6
> Shares Price
> 470 26.6
> 230 26.04
> 300 25.04
> Shares Price
> 300 49.58
> 230 46.2
> 100 36.04
> 130 39.42
> 170 42.81
> Shares Price
> 100 36.04
> 130 39.42
> 170 42.81
> 230 46.2
> 300 49.58
The basic rule for methods defined in a class is that each method must be
unique by signature.
A method signature is the method name, plus the parameter list (parameter
type(s), number of parameters, order in which parameters are listed in the
method header). So you can define two methods named Sort in your class as
long as the parameter lists differ. You could write a single Sort method
that takes two arguments, an ArrayList and a flag to indicate ascending or
descending. You could also write two methods, but as it would appear that
the only parameter defined for each would be type ArrayList, the method
names would have to be different.
Here's another design consideration. As you don't define any collection as a
data member in your LongTermLimit class, why would you want to put a Sort
method in that class?
08-14-2009   #3
Curious
Re: Is it possible to define two separate "Sort" methods in the sameclass?
On Aug 14, 12:50*pm, "PvdG42" <p...@xxxxxx> wrote:
Quote:
> "Curious" <fir5tsi...@xxxxxx> wrote in message
Quote:
> > * * * *ArrayList mBuyLimits = new ArrayList();
> > * * * *ArrayList mSellLimits = new ArrayList();
Quote:
> > * *public class LongTermLimit
> > * * * *protected double mPrice;
> > * * * *protected int mShares;
Quote:
> > * * * *public LongTermLimit(double price, int shares)
> > * * * * * *mPrice = price;
> > * * * * * *mShares = shares;
Quote:
> > * * * *public double Price
> > * * * * * *get { return mPrice; }
Quote:
> > * * * *public int Shares
> > * * * * * *set { mShares = value; }
> > * * * * * *get { return mShares; }
Quote:
> > Shares Price
> > 300 25.04
> > 230 26.04
> > 470 26.6
Quote:
> > Shares Price
> > 470 26.6
> > 230 26.04
> > 300 25.04
Quote:
> > Shares Price
> > 300 49.58
> > 230 46.2
> > 100 36.04
> > 130 39.42
> > 170 42.81
Quote:
> > Shares Price
> > 100 36.04
> > 130 39.42
> > 170 42.81
> > 230 46.2
> > 300 49.58
> method in that class?- Hide quoted text -
> - Show quoted text -
I want to use IComparable and define the built-in Sort method. The
collection is mBuyLimits/mSellLimits.
08-14-2009   #4
Curious
I apologize. I meant "CompareTo" method, not "Sort".
I'll need to define my class as below:
public class LongTermLimit : IComparable
public int CompareTo(object obj)
//bla bla
I don't know how to define two separate CompareTo methods, one for the
descending sort, and the other for ascending sort.
08-14-2009   #5
Family Tree Mike
> //bla bla
Set a property in your class that the CompareTo method uses to determine
the sort order within the single method. Set the property depending on
the requirement at the time of call.
Mike
08-14-2009   #6
Curious
On Aug 14, 4:48*pm, Family Tree Mike <FamilyTreeM...@xxxxxx>
wrote:
Quote:
> Curious wrote:
Quote:
> > * *public class LongTermLimit : IComparable
> > * * * * * * public int CompareTo(object obj)
> > * * * * * * * * //bla bla
> the sort order within the single method. *Set the property depending on
> Mike- Hide quoted text -
Thanks for the idea!
RB
Similar Threads for: Is it possible to define two separate "Sort" methods in the sameclass?
Use "lock" in three methods to prevent shared-memory corruption .NET General
When do I have do define variables with "DIM" ? VB Script
In Outlook Express, how can I define the "columns" other than the "InBox" setting Live Mail
Search - Detail View - "Folder" is backwards - can't sort properly Vista file management
Separate hashtable vs $alist | where-object { "key" = "value" } versus something else? PowerShell
