Vista - how to fix There is a problem with this website's securitycertificate
Old 08-14-2009   #1 (permalink)
memo
There is a problem with this website's security certificate.
The security certificate presented by this website was issued for a
different website's address.
Security certificate problems may indicate an attempt to fool you or
intercept any data you send to the server.
We recommend that you close this webpage and do not continue to this
website.
Click here to close this webpage.
Continue to this website (not recommended).
More information
If you arrived at this page by clicking a link, check the website
address in the address bar to be sure that it is the address you were
expecting.
When going to a website with an address such as https://example.com,
try adding the 'www' to the address, https://www.example.com.
If you choose to ignore this error and continue, do not enter private
information into the website.
For more information, see "Certificate Errors" in Internet Explorer
Help.
Thanks! advance!
http://www.reeland.com.vn
Old 08-15-2009   #2 (permalink)
PvdG42
Re: how to fix There is a problem with this website's security certificate
"memo" <dngoctan@xxxxxx> wrote in message
news:344812b6-5f66-4f05-b826-945167de67ce@xxxxxx
> website.
> More information
> expecting.
> Help.
> Thanks! advance!
How to fix what? Is this a site/page that you've developed and deployed to a
server? If so, what tools/techniques did you use to create the security
certificate? I'm asking you for more information because you've posted your
question in a .NET programming discussion group.
If you're seeing this while just using IE as your web browser, you should
post your question to an IE discussion group, like:
microsoft.public.internetexplorer.general
the problem with ndis.sys Blue Screen of Death problem solved? Vista General
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Vista mail
Generic McAfee Problem Message in Vista Problem Reports Vista performance & maintenance
"Problem with this website's security certificate" Vista General
Vista Upgrade Problem - Windows Explorer Loop problem Vista installation & setup
