| | Right-click in explorer Dear Group, I've created an application, which is doing some actions, on several files in defined cataloge. My point is, to add position in ANY right- click menu item in windows explorer on a directory item. Sample: I open My documents, right-click on folder "blah_blah", displayed options "Open, Explore..., Search, (...), Preferences" including my application launcher. The problem is, how do I do it? I suppose I should activate it while installing software - I use VS 2008. Thank you very much for help and best regards, Przemek M. Zawada |
Explorer crashes on right click! | General Discussion | |||
| Right click in Windows Explorer | Vista General | |||
| Right Click On Explorer Menu Bar | Vista General | |||
| Can't right-click on Internet Explorer! | Browsers & Mail | |||
| window explorer right click menu | General Discussion | |||
