Vista - add a reference
Old 09-05-2009   #1 (permalink)
Georg
add a reference
in a vb2003/5 application i cannot add a reference to mine application . I
allways get an error "a reference to 'D:\path_of_the_dll' to be added is not
possible. Please make sure that the file is accessible, and that is a valide
assembly or COm component"
how can i fix this ?
thx, georg
Old 09-05-2009   #2 (permalink)
Family Tree Mike
Re: add a reference
Georg wrote:
Quote:
> Hi,
> thx, georg
What version of vb.net did you use to build "d:\path_of_the_dll"?
Mike
Old 09-05-2009   #3 (permalink)
Georg
Re: add a reference
hi,
i have this problem in a visual basic 2005 version. I also tried this on a
pc where visual studio 2008 is installed, but the same error shows up.
regards, Georg
"Family Tree Mike" <FamilyTreeMike@xxxxxx> schreef in bericht
news:u6qYsumLKHA.2408@xxxxxx
Quote:
> Georg wrote:
Quote:
>> Hi,
>> I allways get an error "a reference to 'D:\path_of_the_dll' to be added
>> is not possible. Please make sure that the file is accessible, and that
>> is a valide assembly or COm component"
>> thx, georg
> Mike
Old 09-05-2009   #4 (permalink)
Family Tree Mike
Re: add a reference
Georg wrote:
Quote:
> hi,
> regards, Georg
So the dll and the executable to reference the dll are all being built
with the same version of VB.Net? That seems very odd.
Have you tried putting both projects into one solution, then adding the
reference as a project, rather than navigating to the dll itself?
Mike
>>web reference .NET General
To Reference Interop.XXX.dll or XXX.dll .NET General
Best Reference PowerShell
Best reference for .NET for use with PS PowerShell
