Vista - Explorer.exe does not load up on starup.
Old 09-08-2009   #1 (permalink)
Windows Vista Home Premium (32 - BIT)
Hi
For the past week i've had this problem where i would turn on my computer and after the log in screen it would tell me that Windows Explorer stop responding.
So far I've tryed:
- Doing both System Restore and Startup repair using the Windows Vista disc and no luck.
- Going to regedit and checking the shell fine ... but its fine because it has "explorer.exe" in it.
As for that i haven't trying much with this situation.
I can fix it temp by doing CRTL-ALT-DELETE > Task Manger > New Task > explorer.exe but that only does it till the system is turned off and i want to completely fix this problem so my computer starts up normaly.
Old 09-10-2009   #2 (permalink)
Hans Kesting
Re: Explorer.exe does not load up on starup.
Pete975 used his keyboard to write :
Quote:
> Hi
> So far I've tryed:
> disc and no luck.
You might have better luck in a "windows" newsgroup. This one is for
programming problems on the .net platform.
Hans Kesting
Windows Starup 2 pop ups Vista General
Starup Repair Vista General
Starup programs Vista General
Allow Starup Programs? Vista General
explorer and browser won't load Vista General
