Vista - Doubts using BuildTask.Dll - Auto-increment Assembly/File versions
Old 09-15-2009   #1 (permalink)
Christiano
Hey there...
I'm using this BuildTask.dll (
http://www.codeproject.com/KB/dotnet...t_Version.aspx ) to
auto-increment my assembly/file number.
On the main application file it works beautifuly... But my App has 11 class
libraries.
When I try to use this with this class lib, when compiled and versioned, it
conflicts on the main app, due wrong assembly version.
What should be the best practice to do?
- Keep the projects apart from the solution, updating them on the main app
on each update, considering that most of them are quite stable, requiring
just a few modifications here and there..
- Change the versions manually
- Other options??
All the projects are referenced in the same solution file.
Running VS2005SP1.
VB and C# projects
Tks in advance,
christiano.
PSSnapin Assembly .config file PowerShell
Exception: Could not load file or assembly or one of its dependenc PowerShell
[Reflection.Assembly]::LoadFile locks file PowerShell
