Vista - How to partition XP Pro disc without reformatting
Old 09-19-2009   #1 (permalink)
D5oug
Just bought this used Dell 670 with XP Pro loaded. Nothing else is on it
yet. How do I partition the drive for optimal performance. It's 80 Gig.
Also, how much should I partition? Thanks
Old 09-19-2009   #2 (permalink)
PvdG42
Re: How to partition XP Pro disc without reformatting
"D5oug" <D5oug@newsgroup> wrote in message
news:15E5149A-7F1D-4FF2-8DDF-6AD99C9A37FF@newsgroup
With a drive that small, having only a single partition makes sense.
On a somewhat different note, you've asked your XP question in a discussion
group for .NET programming issues, and you'll get more/better feedback if
you ask in a group for XP. Here's how to find the group(s) you need.
As you appear to be using a web interface, visit this page:
http://www.microsoft.com/communities/newsgroups/en-us/
In the tree on the left, open English, then open Windows. In the
Windows subcategory, find and open the subcategory for Windows XP, and
find a group there for your post.
Old 09-21-2009   #3 (permalink)
Gregory A. Beamer
=?Utf-8?B?RDVvdWc=?= <D5oug@newsgroup> wrote in
news:15E5149A-7F1D-4FF2-8DDF-6AD99C9A37FF@newsgroup:
> it yet. How do I partition the drive for optimal performance. It's
> 80 Gig. Also, how much should I partition? Thanks
Dynamic disk is built in, but they have to have set it up to use it. Then
you also have to have the disk defragged where everything is off the space
you wish to use for a second partition. If you end up screwing things up,
you can always reinstall. On most computers these days, do not delete the
current second partition, as it contains your reinstall bits.
Why do you want a second partition anyway? If for performance, you will not
really gain much, if any, as both are on the same disk. If to more easily
back up your files, I can see that. Just curious. As the other poster
posted, 80GB is a bit small to chunk up, at least these days.
Peace and Grace,
Gregory A. Beamer
MVP; MCP: +I, SE, SD, DBA
Twitter: @gbworld
Blog: http://gregorybeamer.spaces.live.com
My vacation and childhood cancer awareness site:
http://www.crazycancertour.com
| Think outside the box! |
Old 09-21-2009   #4 (permalink)
Michael D. Ober
"Gregory A. Beamer" <NoSpamMgbworld@newsgroup> wrote in message
news:Xns9C8D641EF9AECgbworld@newsgroup
At 80 Gb, don't repartition.
Mike.
Old 09-22-2009   #5 (permalink)
Gregory A. Beamer
"Michael D. Ober" <obermd.@newsgroup> wrote in
news7idnW2kKfz0pSXXnZ2dnUVZ_uWdnZ2d@newsgroup:
Have in the past, would not today. Funny how having more bandwidth changes
your view o fthe world. ;-)
Peace and Grace,
Gregory A. Beamer
Twitter: @gbworld
windows cannot install to disc the selected disc is gpt partition style General Discussion
Logical Disc Mgr denies access to partition General Discussion
Partition / Vista And Dynamic Disc Problem General Discussion
Recovery partition and disc question General Discussion
disc partition Vista General
