Vista - Application help
Old 10-07-2009   #1 (permalink)
vaib
Application help
Hi All,
I am trying to build a POP3 client application for my machine. I know
what POP3 is used for and nothing much.
I would simply like to download mails from the server using TCP/IP and
save them to my hard disk using POP3.
Can anyone here suggest me the approach that I should take in tackling
this problem ? Please consider me a complete novice in this area. I
don't want any technical details as such but just the step by step
approach to handle the problem.
Thanking in anticipation.
- Vaibhav
Old 10-07-2009   #2 (permalink)
PvdG42
Re: Application help
"vaib" <vaibhavpanghal@newsgroup> wrote in message
news:5faf033c-3cc4-43a8-ad3b-58b820bbe215@newsgroup
Quote:
> Hi All,
> - Vaibhav
Please see the response in academic. In future, please cross post instead of
multiposting.
application for editing resource in exe application (C#) .NET General
Send to function wont open WinMail and attach pdf from adobe application. I know this can be accomplished by right clicking on the pdf file but I need the application to do the task. Any suggestions? Vista mail
appdata-local-Application Data-Application Data-Application Data infinitum ad nauseum. WHY Vista General
Application Error - CD MFC Application has stopped working Vista General
