| | Click-Once deploy error after updating IE6 to IE7 We have an app (VS 2005, C#) that we have been running for over two years with out issue, but when we upgraded our client PCs to IE7 (from IE6), most had an issue with running the app. When the user tried to start the program, they receive an error (Unable to start application). If I look in the log I see the following error: PLATFORM VERSION INFO Windows : 5.1.2600.131072 (Win32NT) Common Language Runtime : 2.0.50727.3082 System.Deployment.dll : 2.0.50727.3053 (netfxsp.050727-3000) mscorwks.dll : 2.0.50727.3082 (QFE.050727-3000) dfdll.dll : 2.0.50727.3053 (netfxsp.050727-3000) dfshim.dll : 2.0.50727.3053 (netfxsp.050727-3000) ERROR DETAILS Following errors were detected during this operation. * [10/27/2009 3:36:24 PM] System.Runtime.InteropServices.COMException - The referenced assembly is not installed on your system. (Exception from HRESULT: 0x800736B3) - Source: System.Deployment - Stack trace: at System.Deployment.Internal.Isolation.IStore.GetAssemblyInformation(UInt32 Flags, IDefinitionIdentity DefinitionIdentity, Guid& riid) at System.Deployment.Internal.Isolation.Store.GetAssemblyManifest(UInt32 Flags, IDefinitionIdentity DefinitionIdentity) at System.Deployment.Application.ComponentStore.GetAssemblyManifest(DefinitionIdentity asmId) at System.Deployment.Application.ComponentStore.GetSubscriptionStateInternal(DefinitionIdentity subId) at System.Deployment.Application.SubscriptionStore.GetSubscriptionStateInternal(SubscriptionState subState) at System.Deployment.Application.ComponentStore.CollectCrossGroupApplications(Uri codebaseUri, DefinitionIdentity deploymentIdentity, Boolean& identityGroupFound, Boolean& locationGroupFound, String& identityGroupProductName) at System.Deployment.Application.SubscriptionStore.CommitApplication(SubscriptionState& subState, CommitApplicationParams commitParams) at System.Deployment.Application.ApplicationActivator.InstallApplication(SubscriptionState& subState, ActivationDescription actDesc) at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl) at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state) COMPONENT STORE TRANSACTION DETAILS No transaction information is available. I have searched on the net but the only solution I have found is to delete the %userprofile%\Local Settings\Apps folder. This worked fine, but I am having to do this over and over for the same users. Is there a better solution? Thanks for your time, Tim |
| Error When Updating To new MSN Messenger | Live Messenger | |||
| When I click start, games, then click on a game I get this error message: | Vista General | |||
| Updating Calendar Error | Live Mail | |||
| Error code when updating ... | Vista performance & maintenance | |||
| Updating error code 634. | Vista General | |||
