Vista - Using XmlSerializer for derived classes
Old 4 Weeks Ago   #1 (permalink)
nagar
I'm using XMLSerializer to serialize an object that contains a generic
list
List <ChildBase> Children {get;set}
The problem is that each element derives from `ChildBase` which in
fact is an abstract class.
When I try to deserialize, I get an invalidOperationException
Is there a way I can use XMLSerializer with derived objects?
Thanks.
Andrea
Old 4 Weeks Ago   #2 (permalink)
Family Tree Mike
Re: Using XmlSerializer for derived classes
nagar@newsgroup wrote:
> list
> Thanks.
> Andrea
I think we need to see what you are doing. This case shows how it
should work:
namespace ConsoleApplication1
[XmlInclude(typeof(Car))]
[XmlInclude(typeof(Truck))]
public class Container
public List<ChildBase> Children { get; set; }
public Container() { Children = new List<ChildBase>(); }
public abstract class ChildBase {}
public class Car : ChildBase
public Car() { }
public class Truck : ChildBase
public Truck() { }
class Program
static void Main(string[] args)
StringBuilder sb = new StringBuilder();
StringWriter sw = new StringWriter(sb);
Container c = new Container();
c.Children.Add(new Truck());
c.Children.Add(new Car());
XmlSerializer s = new XmlSerializer(typeof(Container));
s.Serialize(sw, c);
StringReader sr = new StringReader(sb.ToString());
Container d;
XmlSerializer t = new XmlSerializer(typeof(Container));
d = (Container) t.Deserialize(sr);
d.Children.ForEach(x => Console.WriteLine(x));
Console.WriteLine("Done");
Console.ReadKey();
Mike
Old 3 Weeks Ago   #3 (permalink)
nagar
It worked. Thanks.
Andrea
On Thu, 29 Oct 2009 19:51:59 -0400, Family Tree Mike
<FamilyTreeMike@newsgroup> wrote:
>> list
>> Thanks.
>> Andrea
>should work:
> public Car() { }
> public Truck() { }
> class Program
> s.Serialize(sw, c);
> Container d;
> Console.ReadKey();
XmlSerializer problem - help? .NET General
XmlSerializer FileNotFoundException .NET General
