Vista - Why does .NET v3.5-SP1 fail? v3.0 required? MSI return code 1603
Old 2 Weeks Ago   #1 (permalink)
Richard Carver
I tried to install .NET v3.5+SP1 on my WinXP+SP3. Unfortunately it fails.
Why?
The log window shows the following error (ignore line wrapping):
[11/07/09,17:33:10] Microsoft .NET Framework 3.0 SP2 x86: [2] Error: Installation failed for component Microsoft .NET Framework 3.0 SP2 x86. MSI returned error code 1603
[11/07/09,17:33:16] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.0 SP2 x86 is not installed.
[11/07/09,17:38:22] Microsoft .NET Framework 3.0 SP2 x86: [2] Error: Installation failed for component Microsoft .NET Framework 3.0 SP2 x86. MSI returned error code 1603
[11/07/09,17:38:28] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.0 SP2 x86 is not installed.
Has v3.0 already to be present? I though since v2.0 .NET is cumulative?
How can I find out which .NET version(s) are already installed on my computer?
Richard
Return code VB Script
"select Name,Path from Win32_Share" permissions required by ASP.NET to return paths, Vista security
FTP return code VB Script
COM+ Event System detected a bad return code Vista General
New activation code required???? Vista General
