Lookup in DataGridView? Any Progress? Worth Trying?
  1. #1
    Patrick A Guest
    In a DataGridView, is it possible to have a column that manages user
    input by providing a "drop down" list of values the user can choose
    from, with those values either being "spelled out" in code or read
    from another db.table.column?
    If so, does anyone know where I might find instructions on how to set
    that up?
    I've seen lots of old posts on this topic, but nothing necessarily
    specific to the latest incarnation of the DataGrid, the DataGridView.
    Is it worth trying to pop a List Box on the ColEdit event, let the
    user "select" from the List Box, and "write" the value the user
    selects to the cell they are editing?
    Thanks,
    Patrick
  2. #2
    Patrick A Guest
    Re: Lookup in DataGridView? Any Progress? Worth Trying?
    Was just told about the
    microsoft.public.dotnet.framework.windowsforms.controls group, and may
    have found my answer.
    Anyone had luck with this?
    Column Types in the Windows Forms DataGridView Control
    http://msdn.microsoft.com/en-us/library/bxt3k60s.aspx
  3. #3
    Family Tree Mike Guest
    > that up?
    > Thanks,
    > Patrick
    It sounds like you want a DataGridViewComboBoxCell. Look here:
    http://msdn.microsoft.com/en-us/libr...boboxcell.aspx
    Mike
Lookup values Morphius PowerShell 3 11 Sep 2009
DNS Lookup DaveMills Server General 11 20 Aug 2009
Re: DNS - Reverse lookup configuration david Vista Forums 3 22 Jul 2009
dn -> sam acct lookup jws PowerShell 10 10 Mar 2008
Reading the Powershell progress bar (activity + progress) with C# a5f PowerShell 3 30 Dec 2007
