I am having encode & decode functions in C.
Will get an encoded value in vb.net & this must be decoded using vb.net code.
How can I apply this?
The decode function in C is
/*Decode function to decode the incoming buffer containing encoded data*/
void decode(char *inbuf,int sizeInbuffer,char *outbuf,int *decodeoutbufsize)
/*Local Declaration*/
unsigned char in[4], out[3], v;
int i, len,j;
int counter=0;
int a1=0;
for(j=0;j<sizeInbuffer;j=j+4)
for( len = 0, i = 0; i < 4; i++ )
v = 0;
while(v==0)
v=(unsigned char) inbuf[counter++];
v = (unsigned char) ((v < 43 || v > 122) ? 0 : cd64[ v - 43 ]);
if( v )
v = (unsigned char) ((v == '$') ? 0 : v - 61);
len++;
if( v )
in[ i ] = (unsigned char) (v - 1);
if( len )
decodeblock( in, out );
memcpy(outbuf+a1,out,3);
// printf("%d",strlen(outbuf));
a1+=3;
*decodeoutbufsize = a1; //Done at SetDecodedLengthForOrderMsg(). Subtract by 2 since we have only 439 bytes, Last 1 byte also decoded with more than one byte(i.e, two bytes).
return;
Regards
Valli
