Configuring XML Serialization to not add an element
  1. #1
    Yash Ganthe Guest
    I have the follwoing class structure:
    public class MyClass {
    public Fields Fields;
    public partial class Fields {
    public BaseField[] myFields;
    [System.Xml.Serialization.XmlInclude(typeof(DerivedField))]
    public class BaseField
    //some properties
    [XmlRoot("derived")]
    public partial class DerivedField : BaseField {
    All the classes are tagged as serilizable.
    When I XMLSerialize an object of type MyClass, here is what I get:
    <MyClass>
    <Fields>
    <myFields>
    <derived name="JobID" id="A" precision="9" />
    </myFields>
    </Fields>
    </MyClass>
    The serializer adds an XML element for every public property, which is
    why myfields appears as a tag in the XML.
    This is undesirable in my application as I would like the elements in
    myFields[] to get serialized directly under <Fields> as :
    <MyClass>
    <Fields>
    <derived name="JobID" id="B" precision="9" />
    <derived1 name="JobID" id="C" precision="9" />
    <derived2 name="JobID" id="D" precision="9" />
    </Fields>
    </MyClass>
    Is there a way to instruct the serializer using Attributes or some
    other to not add a tag for the myFields array?
    Thanks,
    Yash
  2. #2
    Hovhannes Terteryan Guest
    Re: Configuring XML Serialization to not add an element
    I suppose you either need to implement IXmlSerializable in MyClass, or make
    the class Fields as a collection.
    "Yash Ganthe" <yashgt@newsgroup> wrote in message
    news:95a32c1f-df23-4221-a775-fe92a50f3c28@newsgroup
    > Hi,
    > //some properties
    > <MyClass>
    > <Fields>
    > <myFields>
    > </myFields>
    > </Fields>
    > </MyClass>
    > <MyClass>
    > <Fields>
    > </Fields>
    > </MyClass>
    > Thanks,
    > Yash
  3. #3
    Family Tree Mike Guest
    RE: Configuring XML Serialization to not add an element
    "Yash Ganthe" wrote:
    > Hi,
    > //some properties
    > <MyClass>
    > <Fields>
    > <myFields>
    > </myFields>
    > </Fields>
    > </MyClass>
    > <MyClass>
    > <Fields>
    > </Fields>
    > </MyClass>
    > Thanks,
    > Yash
    You can use XmlIgnore as in the following:
    [XmlIgnore()]
    Mike
Configuring XML Serialization to not add an element problems?
Serialization optimization guy1976 .NET General 3 11 Dec 2008
WCF Custom Serialization Vikas Indigo 0 04 Jun 2008
XML Serialization Tom .NET General 5 16 Apr 2008
Serialization Reference Alhambra Eidos Kiquenet Indigo 1 31 May 2007
Serialization frameworks on .net 3.0 Robin Davies WinFX General 0 13 Nov 2006
