Difference of cast between c++ and c# ?
  1. #1
    Scotty Guest
    If I do a (char)-1 in c++ and c# I get a different result: 'ÿ' and '.'
    Why is that please ?
  2. #2
    PvdG42 Guest
    Re: Difference of cast between c++ and c# ?
    "Scotty" <matthieu.sarthou@newsgroup> wrote in message
    news:d0dc9d86-b46f-4076-9b40-f44443198156@newsgroup
    > Hi,
    What character set defines characters associated with negative numeric
    values?
    If you cast a defined value, do you get the same result in both languages?
    By C++, are you referring to ISO standard or C++/CLI?
    Bottom line: different languages provide different responses to illogical
    input.
  3. #3
    Family Tree Mike Guest
    RE: Difference of cast between c++ and c# ?
    "Scotty" wrote:
    > Hi,
    First, your code would have been:
    char c = unchecked((char) -1);
    to avoid a compiler error. That would tell you something is amiss.
    As PvdG42 wrote, the behavior is rather ill-defined. In fact, when I run
    the code above, I get a question mark for any negative number.
    Mike
  4. #4
    ib.dangelmeyr Guest
    Maybe because 'char' is 8 bits in C++ and 16 bits in C#?
    C++: -1 (255) results in (ANSI-Codepage) in 'ÿ'
    C#: -1 (65535) results in an illegal Unicode character.
Difference of cast between c++ and c# ? problems?
Type cast Joachim Meyer PowerShell 1 26 Aug 2008
Specified cast is not valid RW .NET General 3 06 Mar 2008
meaning of this cast ? Leo Tohill PowerShell 3 15 Nov 2007
Verizon V-cast software justbob30 Vista General 2 14 Aug 2007
Yellow cast issue... MiKeV Vista music pictures video 1 09 Feb 2007
