system.net.webclient post timeout
  1. #1
    Blueparty Guest
    I am Java programmer who is forced to do something in .NET for the first
    and, also, the last time in my life.
    I have console application in vb.net which is retrieving data from
    Tomcat web server using GET method, and uploading some other data using
    POST method. I am using system.net.webclient and it works fine.
    When I try to add basic authentication, GET still works fine, but POST
    takes very long to complete. I have checked Tomcat logs, and request is
    served swiftly, as normal, but vb.net application does not seem to be
    aware of that, as if it is waiting for some kind of acknowledge.
    I am adding NetworkCredential as webclient.credentials property.
    I have also tried adding NetworkCredential to CredentialCache, and
    setting webclient.credentials to CredentialCache, but there is no
    improvement.
    I repeat, everything works perfectly without authentication. Is there
    any way to speed up POST request, apart from removing authentication ?
    B
  2. #2
    Blueparty Guest
    Re: system.net.webclient post timeout
    >> improvement.
    >> B
    > Do you have your code in a try/catch block?
    > Does your code setting the credentials look something like this?
    > Dim client As New WebClient
    > client.Credentials = New NetworkCredential("user1", "password")
    > Can you post your code that is failing to give us some idea as to how we can
    > help you fix it?
    > Mike
    Thanks for your interest. Here are the relevant parts:
    dim cred as new NetworkCredential("user","password")
    dim credCache as new CredentialCache()
    credCache.add(new Uri("http://192.168.0.2:8080/"),"Basic",cred)
    function getHttpData(byval url as string,byref result as string) as integer
    dim agent as WebClient=new WebClient()
    agent.credentials=credCache
    dim ret as integer=1
    result=""
    console.writeline("GET started")
    try
    result=agent.DownloadString(url)
    ret=0
    catch e as Exception
    log.writeLine("GET method failed")
    end try
    console.writeline("GET finished")
    return ret
    end function
    function putHttpData(byval url as string, byval sdata as string) as integer
    dim str3 as string=HttpUtility.urlEncode(sdata)
    str3="alldata=" & str3
    agent.Headers.Add("Content-Type", "application/x-www-form-urlencoded")
    dim outData as string
    console.writeline("POST started")
    try
    outData=agent.uploadString(url,str3)
    ret=0
    log.writeline(outData)
    log.writeLine("POST method failed")
    log.writeLine(e.toString())
    end try
    console.writeline("POST finished")
    return ret
    end function
    I also tried without CredentialCache, supplyind NetworkCredential
    directly, as I said. One more thing. IE does POST normaly, without any
    delays, from the same machine and to the same site.
    Function 'getHttpData' runs before 'putHttpData'. 'getHttpData' runs
    normally, while 'putHttpData' is causing long delays. You can see
    console output, so it is very clearly visible how long does any
    operation take.
    I also tried to change the order of
    and
    but, nothing happened..
    B
system.net.webclient post timeout problems?
Using System.Net.WebClient and no cache Fenster PowerShell 3 08 Oct 2008
Backup system crashes and hard drive timeout John Vista hardware & devices 0 06 May 2008
Q: System.Net.WebClient Robertico PowerShell 2 07 Apr 2008
System Health Report Timeout Error Luc M Vista performance & maintenance 3 18 Mar 2008
System.Net.WebClient and XML Marco Shaw PowerShell 5 06 Mar 2007
