Re: .NET 3.5 - System.Reflection.Assembly does not release object (DLL
  1. #1
    Wolfixx Guest
    > Armin Zingler responded to your post in the VB.Net group several days ago.
    > From his post:
    > Look at the big "Note" in the middle:
    > http://msdn.microsoft.com/en-us/library/2bh4z9hs.aspx
    > I've no experience with it but maybe you find something
    > in the neighbour topics (about assemblies and application domains).
    Yes I know but the answer doesn't help me. I though it belong to this
    newsgroup anyway because it is an issue with the .Net Framework and not VB
    specific.
    Any other ideas?
  2. #2
    Wolfixx Guest
    "Wolfixx" <wolfixx@newsgroup> wrote in message
    news:#bTCOx51KHA.4832@newsgroup
    >> ago.
    >> From his post:
    > specific.
    > Any other ideas?
    Ignore me. The answer fitted - it's just not possible
Re: .NET 3.5 - System.Reflection.Assembly does not release object (DLL problems?
Less verbose [System.Reflection.Assembly]::LoadFrom() ? RCN PowerShell 2 11 Jun 2009
Re: Unable to cast COM object of type 'ADODB.RecordsetClass' to class type 'System.Object[]' Michel Posseth [MCP] .NET General 2 27 Mar 2008
DataBinding to object in external assembly Philipp Schmid Avalon 2 14 Feb 2007
[Reflection.Assembly]::LoadFile locks file npoto PowerShell 5 19 Nov 2006
Adding canonical aliases for Compare-Object, Measure-Object, New-Object Alex K. Angelopoulos [MVP] PowerShell 2 26 May 2006
