audio codecs
  1. #1
    DaveMat Guest
    audio codecs
    Hi
    I have accidentally deleted my audio system from my laptop...I have tried
    system restore but this has not helped...any suggestions please
  2. #2
    PvdG42 Guest
    Re: audio codecs
    "DaveMat" <DaveMat@newsgroup> wrote in message
    newsB18D73B-8B09-41AA-A816-2D2CEEB4DFE8@newsgroup
    > Hi
    As this discussion group is for .NET issues, you're unlikely to get a lot of
    help here. I'd suggest going to your laptop manufacturer's tech support as a
    first step.
    Have you tried removing the sound device hardware from Device Manager, then
    allowing your OS to rediscover the hardware and reinstall drivers?
audio codecs problems?
Realtek HD Audio Codecs Burnboy Sound & Audio 12 19 Nov 2008
audio codecs Darlene McDaniel Vista hardware & devices 2 16 Feb 2008
audio compression codecs goth_chick Vista performance & maintenance 4 06 Dec 2007
Uninstall video and audio codecs calamar Vista General 0 13 Nov 2007
Audio Codecs - Old Time Radio Candlabra Vista General 2 10 Jun 2007
