Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Go Back   Vista Forums > Vista Forums > Network & Internet
Sudden upload speed slowdown
Update your Vista Drivers Update Your Drivers Now!!
Thread Tools Display Modes
Old 05-08-2008   #1 (permalink)
Newbie
Vista Home Premium x64
Phoenix0783 is on a distinguished road
  Phoenix0783 is offline
A few days ago out of the blue my upload speed went down to practically zero. I know it's my computer because the other computers on the network can still upload fine. When I run a speed test the download comes back fine (~1275kbps on a 1536kbps connection) but the upload either doesn't finish or comes back at something like 10kbps. My connection for upload is 800kbps. I use qwest dsl. Thank you for any help.
Old 05-08-2008   #2 (permalink)
sidney1st's Avatar
Ultimate SP1 x64 & x86
Paris
sidney1st has a reputation beyond reputesidney1st has a reputation beyond reputesidney1st has a reputation beyond reputesidney1st has a reputation beyond reputesidney1st has a reputation beyond reputesidney1st has a reputation beyond reputesidney1st has a reputation beyond reputesidney1st has a reputation beyond reputesidney1st has a reputation beyond reputesidney1st has a reputation beyond reputesidney1st has a reputation beyond repute
  sidney1st is offline
Re: Sudden upload speed slowdown
First of all, are you sure that the other computers are not uploading (P2P) and therefore use the bandwith?
If not, how is configured your connection ? (router, ethernet, wireless, usb)
Old 05-08-2008   #3 (permalink)
Newbie
no one is using any p2p, or doing any other uploading.
i'm using wired ethernet. from my router/gateway (netgear dg834g) a cable goes to a switch, which then branches out to the other computers. the router has wireless enabled for laptops but the computer that is having problems doesn't use it. my network card is an integrated nvidia.
Old 05-08-2008   #4 (permalink)
sidney1st's Avatar
Paris
Humm, could come from a connection problem with the router or AV/fiewall even other computers have no problems. I am guessing that you tested the cable and switch port and made tests with the firewall an AV disabled as i know that for example with Norton sometimes very weird things occur with regards to the Internet connection.
If you have still the problem, delete your entire connection to the network, reboot, deactivate firewall (including the vista firewall if it's on) and reconstruct your connection, it is easy and simple to do it.
Old 05-08-2008   #5 (permalink)
Newbie
I can't delete the connection, only disable it. The delete option is grayed out whether the connection is disabled or enabled. If I press the delete key it says that the connection can not be deleted.
Old 05-09-2008   #6 (permalink)
sidney1st's Avatar
Paris
I think that you have first to deactivate your network card.
1/ Deconnect from network
2/ Deactivate/deinstall Network card
Then try to delete connection.
BTW, no change with firewall/AV deactivation ?
What AV/Firewall do you use ?
Old 05-09-2008   #7 (permalink)
Newbie
I did deactivate the network. I also can't remove the network adapter in device manager. I turned of Windows firewall and my avg.
Old 05-09-2008   #8 (permalink)
sidney1st's Avatar
Paris
I guess no improvement...
Copy/past your network card settings (properties/advanced tab)
Can you connect via Wifi?
Could be an IRQ conflict, check that.
Sid.
Old 05-11-2008   #9 (permalink)
Newbie
flow control: disabled
interrupt moderation: enabled
lower power state link speed: disabled
priority & vlan: priority enabled
speed & duplex settings: auto negotiation
vlan id: 1
wakeonlan from poweroff: disabled
Display Modes
Extremely Slow Upload Speed to Server 2k3 02ztsfocus Vista networking & sharing 2 06-09-2008 10:12 PM
Slow Upload Speed ShadowKitsune Network & Internet 7 05-24-2008 10:44 AM
Sudden slowdown in Vista Steve Vista performance & maintenance 1 12-17-2007 11:23 AM
amount of ram, cpu speed and vista score disapeared all of the sudden Jabes Vista performance & maintenance 7 11-01-2007 08:42 AM
SLOW UPLOAD SPEED IN VISTA? AL SMITH Vista General 4 09-10-2007 11:51 AM
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
