| Welcome to Vista Forums we are your forum to discuss Windows Vista x64 and x86 systems. |
| | Thread Tools | Display Modes |
| Newbie ![]() Join Date: May 2008 Vista Business 32bit
| how to auto connect to wireless networks which requires identification? i've set my laptop to auto-connect to a wireless network, but it'll ask for identification because it's a secure network. is it possible to automate the filling process too, so that i don't have to type everytime? i have to enter my username, password and another field which i can't rem. >.< there is a check box on the prompt pop up screen which says that the above information can be saved when checked, but it's greyed out, so i couldn't check it. sorry if there's another thread of the same kind elsewhere, but i don't know where to find help of this type. |
| Graphics Freak ![]() ![]() ![]() Join Date: May 2008 Vista Home Premium 64bit
Location: Orlando, FL | Re: how to auto connect to wireless networks which requires identification? Down in the right corner of your monitor near your time in your system tray should be a network icon for wireless connection. Right click on it, select connect to, or view available wireless networks, select your network and enter the WEP or security key you got with your router, if you are unsure of your key consult your routers documentation or the router manufacturers website on how to obtain that info. Once you connect and input the key you should be on the network and receive a valid IP and be able to browse. Try this out! |
| Core 2 Quad Q6600 4gig's OCZ Reaper DDR2 - 1066 Asus PK5-E Mobo BFG 8800GT OC Seagate 500Gig 32M Cache HD SB Audigy2 Z Platinum Coolermaster 600W PSU Antec Nine Hundred Case Samsung 216BW 22" LCD Widescreen Windows Experience Score 5.7 Geek Bench Score 4020 | |
| Re: how to auto connect to wireless networks which requires identification? er, i can auto-connect. but i want to make my username and password for secured networks automatically filled in for me, so i don't have to keep typing it everytime i want to connect. it's esp bad when the laptop just doesn't seem to accept my correctly type username and password, causing me to enter multiple times before finally connecting. |
Location: Orlando, FL | Re: how to auto connect to wireless networks which requires identification? Unless there is a remember password box and you have set windows or IE to autofill I don't think what you are asking is going to be possible. I could be wrong though. :P |
| | #7 (permalink) |
| Re: how to auto connect to wireless networks which requires identification? er.. here goes.. security type: 802.1X encryption type: WEP choose a network authentication method: Protected EAP (PEAP) [checked] cache user information for subsequent connections to this network when my laptop automatically finds the network, it will show a notification at the bottom right corner that says something like "additional information is required to connect to this network". i'll have to click that and fill in my username etc. |
| | #8 (permalink) |
| Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008 Ultimate SP1 x64 & x32
Location: Paris | Re: how to auto connect to wireless networks which requires identification? I guess you use a special identification which has nothing to see with your Windows login/password. The greyed out box is (i think) related only with your Windows login. If is is a professional or university network, maybe you have to enter your login/password each time you connect to the network. |
