br> br> |
| | Thread Tools | Display Modes |
| Newbie Rep Power: 3 ![]() | IP Address help! Home Premium Ok i need some help, with changing my IP Address. Details; i'm with Virgin media broadband i'm using a cable modem.. and i've read how to change it; Via the Network > Manage network connections > Porperties... Doesnt work it tells you... "Obatain and IP address automatically." But mine is already set to that... and with the "Use this IP address." option i don't know what to put in, for the simple fact i wouldnt want to put in an invalid IP... Please somebody help! ![]() ![]() |
| Member ![]() Rep Power: 66 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | Re: IP Address help! Home Premium Hi Whiteley, Did you already have a connection or are you setting it up? Can you give us some more information. Run the command prompt console and type in: ipconfig /all Copy/past the result. |
| Member Rep Power: 7 ![]() | Re: IP Address help! Home Premium set the IP Version to 4 vista might end up using the IPV6 follow the steps below : 1. Open Network Connections by clicking the Start button , clicking Control Panel, clicking Network and Internet, clicking Network and Sharing Center, and then clicking Manage network connections. 2. Right-click the connection that you want to change, and then click Properties. If you are prompted for an administrator password or confirmation, type the password or provide confirmation. 3. Click the Networking tab. Under This connection uses the following items, click Internet Protocol Version 4 |
| Newbie Rep Power: 3 ![]() | Re: IP Address help! Home Premium C:\Users\Dan>ipconfig/all Windows IP Configuration Host Name . . . . . . . . . . . . : Dan-PC Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No Ethernet adapter Local Area Connection 2: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : USB Cable Modem 351000 Physical Address. . . . . . . . . : 00-0E-9B-E5-C9-11 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::2056:8878:6186:577c%10(Preferred) IPv4 Address. . . . . . . . . . . : 81.105.104.19(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.252.0 Lease Obtained. . . . . . . . . . : 18 May 2008 11:17:48 Lease Expires . . . . . . . . . . : 23 May 2008 15:31:13 Default Gateway . . . . . . . . . : 81.105.104.1 DHCP Server . . . . . . . . . . . : 62.252.224.28 DHCPv6 IAID . . . . . . . . . . . : 218107547 DNS Servers . . . . . . . . . . . : 194.168.4.100 194.168.8.100 NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter Local Area Connection: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) PRO/1000 PL Network Connection Physical Address. . . . . . . . . : 00-1C-25-3D-5E-2B DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Tunnel adapter Local Area Connection* 6: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : isatap.{FC799986-BA3F-4FF4-9211-96BDBD7A5 E3E} Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Tunnel adapter Local Area Connection* 7: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : isatap.{54C03730-27C2-48CE-966C-B0874D7D3 780} Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::200:5efe:81.105.104.19%12(Preferred ) Default Gateway . . . . . . . . . : DNS Servers . . . . . . . . . . . : 194.168.4.100 194.168.8.100 NetBIOS over Tcpip. . . . . . . . : Disabled Tunnel adapter Local Area Connection* 9: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : 6TO4 Adapter Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Temporary IPv6 Address. . . . . . : 2002:5169:6813::5169:6813(Preferred) Default Gateway . . . . . . . . . : 2002:c058:6301::c058:6301 DNS Servers . . . . . . . . . . . : 194.168.4.100 194.168.8.100 NetBIOS over Tcpip. . . . . . . . : Disabled Tunnel adapter Local Area Connection* 10: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface Physical Address. . . . . . . . . : 02-00-54-55-4E-01 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::30c3:ba:ae96:97ec%11(Preferred) Default Gateway . . . . . . . . . : NetBIOS over Tcpip. . . . . . . . : Disabled C:\Users\Dan> Don't know if that helped buddy but you wanted it |
| Engineer ![]() Rep Power: 14 ![]() ![]() ![]() ![]() ![]() | Re: IP Address help! Home Premium hi Whiteley, If your setting up a new Connection to the internet the configuration shown in your Ip config is the ISPs IP address whihch is correct. Are you able to connect the internet. If your want to have a small home network or such then you need to configure a manual ip. you could use ferrisits post or. you can go to command propmt and type in the following netsh interface ip set address name="Local Area Connection" static 192.168.0.100 255.255.255.0 192.168.0.1 1 where 192.168.0.100 is the ip address 255.255.255.0 is the subnetmask 192.168.0.1 is the defult gateway. You need to put the Ip address according to your network i have given only a example Hope this Helps . Cheers |
| | #6 (permalink) |
| Newbie Rep Power: 3 ![]() | Re: IP Address help! Home Premium Like what ferrists said i don't get it.. He wants me to input my own IP... But will any IP Work? |
| | #7 (permalink) |
| Member ![]() Rep Power: 66 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | Re: IP Address help! Home Premium Well, try with 194.168.4.210 as your ip address 255.255.255.0 as mask 194.168.4.100 as gateway And dns 1: 194.168.4.100 dns 2: 194.168.8.100 |
| | #8 (permalink) |
| Engineer ![]() Rep Power: 14 ![]() ![]() ![]() ![]() ![]() | Re: IP Address help! Home Premium Hi Whiteley, No you cant use anyip if your connecting to a router your router would have a Ip series it uses you could use a ip from that. If your using a modem that uses a direct link from your ISP then u need to obtain it automaticaly. to get a Ip automaticaly from your ISP do the follwoing in Command Propmpt. open command propmpt. copy paste the following Provided that your connection name is Local area connection netsh interface ip set dns "Local Area Connection" dhcp Hope this helps Cheers !!! |
| | #9 (permalink) |
| Newbie Rep Power: 3 ![]() | Re: IP Address help! Home Premium Sorry mate but the automatic is what it's already set to ![]() I just need to know how to change it |
| | #10 (permalink) |
| Engineer ![]() Rep Power: 14 ![]() ![]() ![]() ![]() ![]() | Re: IP Address help! Home Premium Hi Whiteley, You can change your IP by looking at my previous post. But if you do so like i said you need to know the IP address from your ISP. Normaly ISP s dont give static Ips to users. They used to give it long time back when there were dialup connections. You cant use any ip address beacuse Thoese Ip address wont be valid with your ISP. Hope this helps.. Cheers |
| Display Modes | |
| Remote Access from Vista Home Premium to Vista Home Premium and XP Home Edition | cmacandrew | Network & Internet | 2 | 03-26-2008 06:29 AM |
| Updating from Home Premium to Ultimate and moving Home Premium | mor10 | Vista installation & setup | 6 | 11-18-2007 02:57 PM |
| Retail 32bit vista Home Premium upgrade to 64 bit Home Premium - H | rrdToledo | Vista General | 6 | 09-24-2007 10:38 PM |
| I think I finially got my friends XP Home and Vista Home Premium machines to Share | See signature below | Vista networking & sharing | 0 | 08-27-2007 10:53 AM |
| Windows XP Home (Full Vers.) to Vista Home Premium Upgrade (Academ | TNTeacher | Vista General | 2 | 02-14-2007 10:19 PM |
